Car Dead. Can't put it in neutral?
Old Nov 8, 2009 | 07:28 PM
cray159's Avatar
2005 Acura TL
My car's battery died and I was trying to get it into neutral and push it to a spot someone could jump me.
But for some reason it won't let me.
Anyone have this problem before? or know how to fix it?
Old Nov 8, 2009 | 08:06 PM
riomp300's Avatar
Put the car in II position (when your gauge cluster/radio lights up)
Press brake pedal, put it in Neutral
Old Nov 9, 2009 | 03:41 AM
Turbonut's Avatar
Remove the shift lock cover located to the left side of the “P” on the console. Insert the key into the slot, then push down on the key and move the shift lever out of Park. To release, move the lever to Park, then remove the key.
Old Oct 31, 2019 | 04:34 PM
'14MDXHouston's Avatar
I had the same problem with my 2014 MDX - could not shift into Neutral without engine running and dead battery.
By trial and error, I hit on the solution, nothing in manual about this. (Note: You must have 'some' voltage present, either from low battery or jumper cables, probably at least 10 volts.)
With key fob present, press ‘Start’ button twice then release. Press down on brake pedal. Voila, move shift lever to ‘Neutral’.
Ryley
Feb 27, 2016 03:47 PM
AaronChiles
Jun 24, 2013 04:32 PM
asookazian
Apr 26, 2011 09:37 PM
Nobeep
Jun 14, 2007 09:01 AM
1stGen2.5
1G TL (1996-1998)
Jun 16, 2004 12:55 PM
