Cannot fix vibration
Old Aug 10, 2020 | 06:34 PM
kpayne111's Avatar
So I cannot figure out why my car has a bit of vibration/droning at low speed and idle. I have forked out the money and changed the cheap Chinese mounts with OEMS, changed out my cheaper spark plugs for the OEM NGK Iridiums, cleaned throttle body & EGR, also adjusted valve lash (didn't need much adjustment). None of this made a drastic improvement. The engine seems to run very strong and pretty smooth, no engine codes. I know my motor mounts are holding vaccuum. The small vibration is the same in drive and reverse. Only possibility I can think of is the motor mount solenoid is not allowing a lot of vaccuum to dampen vibration. Any help would be appreciated, thanks.
Old Aug 14, 2020 | 02:28 AM
Robbym's Avatar
What motor mounts did you replace? You may also want to check the mid mounts or whatever they are called. There are two and you can see them with the wheel off. They are connecting the subframe to the chassis of the car. Idk the purpose of them but it’s a start and they are cheap.
Old Aug 14, 2020 | 11:22 AM
csmeance's Avatar
trans mounts! And make sure all the mounts are neutralized after installation.
Old Aug 14, 2020 | 07:14 PM
Midnight Mystery's Avatar
Null and proud of it
Gotta look into mine too.
CLUofI
Aug 12, 2020 11:38 AM
Robs252
5G TLX Problems & Fixes
Jan 19, 2018 08:37 AM
paperboy42190
Apr 29, 2014 06:10 AM
tonester
Jul 25, 2011 05:13 PM
Fireprevention
1G TL Problems & Fixes
Jan 5, 2009 12:26 PM
