Can I pull Engine/Trans from top??
Old Apr 21, 2019 | 03:41 PM
FabesTL22's Avatar
5th Gear
Im in a situation where my 06AT Acura TL trans is taking a crap and I want to attempt the 06-07 v6 accord trans swap. I have 110k miles on it and never did the timing belt water pump so I figured id pull everything out and just make it easier to do it all out the car and put it back in together. I know you can pull the Manual Transmission from the top but I just wanted to confirm the same with the Automatic?? Pls HELP
Old Apr 21, 2019 | 03:52 PM
Of course you can, there are many ways to skin a cat
Old Apr 21, 2019 | 05:47 PM
Midnight Mystery's Avatar
Null and proud of it
Old Apr 21, 2019 | 06:58 PM
nfnsquared's Avatar
IIRC, ETCG did a video of a J32 pull....
Old Apr 21, 2019 | 07:05 PM
He did about three years ago...
Old Apr 23, 2019 | 08:53 PM
FabesTL22's Avatar
5th Gear
Old Apr 23, 2019 | 08:57 PM
FabesTL22's Avatar
5th Gear
thanks I watched it and it can be done. but he did but he also make sure to say bcuz I got a manual I got more space lol
Old Apr 23, 2019 | 09:00 PM
FabesTL22's Avatar
5th Gear
Thanks guys I appreciate the feedback. Im hearing its still fairly easy to pull from the bottom and get clearance to. I guess I Gotta see what's easier with no lift
Old Apr 23, 2019 | 09:07 PM
teh CL's Avatar
Go from the top, especially with no lift.
Old May 25, 2019 | 03:14 PM
mswags's Avatar
4th Gear
i pulled my 04 out of the top. the only hang up is the braided ground strap the tiny bolt just needs to be taken out or it gets hung up on it. still room with an automatic though.
Old May 27, 2019 | 09:26 PM
csmeance's Avatar
some guy did it from the bottom in his driveway by supporting the subframe and then raising the TL up and over the motor/subframe! This would be better since you could replace bushings and other suspension parts a lot more easily!
Old May 27, 2019 | 09:28 PM
Ok! Tie breaker, then?
Old May 27, 2019 | 09:32 PM
csmeance's Avatar
Rock paper scissors works best
Old Jun 5, 2019 | 06:13 PM
Acura TL Builder's Avatar
Just keep the tranny in the engine bay and replace the clutch.
Easy and painless.
Chris Pipkin
1/2G MDX (2001-2013)
Aug 6, 2017 08:04 AM
JDMCRX
Feb 10, 2011 02:26 PM
xenocow
Aug 13, 2010 09:29 PM
reese8789
14
Mar 3, 2010 08:49 PM
jproy
Feb 12, 2008 03:40 AM
