A/C Trouble
Old Jan 10, 2014 | 04:38 PM
Jase13's Avatar
A/C Trouble
For the last few months my A/C has had a mind of it's own. Sometimes it blows cold and sometimes it doesn't. It seems as though the compressor only kicks on sometimes. It is charged and at proper levels and my fans work so I'm not sure if there is something that decides when/when not to kick on the compressor that is faulty. Any help is greatly appreciated. 2007 TL.
Old Jan 10, 2014 | 04:54 PM
TLer trash's Avatar
If you're really sure the system is full, I've had a/c clutch coils cause intermittent problems. Sometimes just removing one of the clutch plate shims will cure it.
Old Jan 10, 2014 | 06:06 PM
Jase13's Avatar
Positive it is full. Checked it today. It is sitting at about 70/120.
Old Jan 10, 2014 | 06:13 PM
Jase13's Avatar
Can you tell me where it is located?
Old Jan 10, 2014 | 06:14 PM
Ccvn0's Avatar
Your compressor is bad. And check on the relay
Old Jan 10, 2014 | 06:36 PM
Jase13's Avatar
I just did the self diagnostic test with the A/C and on the second step when it says Lo and blows full blast, it shuts off. Did that twice. Is that the complete test? If so, nothing illuminated.
Old Jan 10, 2014 | 07:01 PM
Jase13's Avatar
Anyone know which fuses and/or relay it is? My TL did not come with a manual.
Old Jan 10, 2014 | 07:20 PM
bla8291's Avatar
I had the same problem. It was a bad relay. But it could have also been the clutch coil (which I replaced anyway - long story). Your compressor is definitely not bad, since it still kicks on sometimes. The relay is located in the under-hood fuse compartment...but I don't know if there are other relays in there, or if it's the only relay in there amongst the fuses.
Old Jan 10, 2014 | 07:35 PM
Jase13's Avatar
Compressor just recently stopped kicking on completely. Like a few days ago. But it started out as a random.
Old Jan 10, 2014 | 10:02 PM
bla8291's Avatar
Take it to a shop (or maybe Acura) if they don't charge much to check your A/C system. My local shop charges $38 to check every part of the A/C system to see where the problem is. My A/C actually did the same thing...some days it worked like a dream, some days it cut out sometimes, and eventually it went out completely. But I highly doubt your compressor is bad. Like I said, have it checked out. The mechanic will tell you what's wrong.
Old Jan 11, 2014 | 08:01 AM
YeuEmMaiMai's Avatar
Your problem is most likely electrical.
The self test will post a code on the climate control if it fails.
My guess is relay. You can test clutch by applying +12V to it directly after unplugging connector. if it engages and the engine load increases, you are golden in terms of clutch and compressor.
Also, the compressor should not engage when the system reads ambient temps below 32F...it's by design.
Old Jan 11, 2014 | 08:44 AM
Jase13's Avatar
I did it three times and it did not show anything. Just stayed blank and turned off. My load is increasing when I turn the A/C on but the compressor is not kicking on/clicking. I live in Orlando so 32F is not an issue. I have no clue where the clutch or connector are. Can someone please inform me on which fuses/relays I need to check. I can't find a Frickin diagram anywhere. I have looked for hours.
Old Jan 11, 2014 | 08:50 AM
this should give you an idea
Old Jan 11, 2014 | 09:04 AM
Jase13's Avatar
Good video, but what does the video show me about the issue I am having?
Old Jan 11, 2014 | 10:15 AM
it shows you where the connector is for the clutch
Biggie_B
May 27, 2025 05:51 PM
08KBP_VA
Oct 22, 2019 01:55 PM
Jinkazetsukai
Nov 21, 2015 05:28 PM
hashbrown
Sep 29, 2015 12:13 PM
