A/C stopped working over night
Old Aug 2, 2012 | 05:42 PM
catmx's Avatar
Last night A/C was working properly when I parked the car. This morning no cold air at all. Checked a/c compressor clutch is working properly, can see it turn on/off with someone operating switch. Both fans are running when a/c is switched on. Both schrader valves have pressure on them, checked with small screw driver. I don't own a set of A/C gauges at this time. Low pressure side does not even start to get cold and High side does not start to get hot. Could I be missing a blown fuse or something stupid?
Old Aug 5, 2012 | 08:09 PM
catmx's Avatar
Update....Borrowed a buddies set of gauges and checked pressures. When I unscrewed the cover for the High Pressure side I heard a slight swish. Had 70 psi without engine running, engine running High side was only 110 psi and Low side went to 15" of vacuum. Not enough R134 charge. Picked up a new schrader valve kit from auto parts store and a can of R134. Changed valves and recharged...A/C is now working properly.
Old Aug 6, 2012 | 03:29 PM
flyromeo3's Avatar
is it normal to recharge your a/c?
every car I've had I never had to recharge my a/c unless there was a leak someplace.
Old Aug 6, 2012 | 06:11 PM
catmx's Avatar
High pressure schrader valve was leaking.
Old Aug 7, 2012 | 03:14 PM
flyromeo3's Avatar
ok..that answered my question
01CLOwner
Oct 9, 2015 01:07 PM
SilverJ
1/2G MDX (2001-2013)
Sep 21, 2015 02:40 PM
acurajj
Sep 19, 2015 03:47 PM
theinsvnity
Sep 10, 2015 10:22 PM
dlknight
Sep 3, 2015 07:54 PM
