A/C problem
Old Apr 25, 2011 | 11:30 AM
daddyerne's Avatar
Unhappy A/C problem
i ahave a 2005 tl base and the a/c start to cont cool every 4 to 6 minuts i dont know what cant that b , my frien tel me about the thermostat of the a/c
Old Apr 25, 2011 | 02:31 PM
SouthernBoy's Avatar
Registered Member
I haven't a clue what you're asking. Please try this again in a more understandable post so we can try to help you out.
Old Apr 26, 2011 | 12:31 PM
daddyerne's Avatar
ook sorry , i have a 2005 tl , and my a/c cools and stop ever 20 minutes
daddyerne's Avatar
sorry i hope his helps understand
Old Apr 26, 2011 | 12:42 PM
AdamNJ's Avatar
Make MyTL Great Again
are you saying that the compressor comes off and on? that's normal?
are you saying it only works for 20 minutes then all 'cooling' ceases for good?
Old Apr 26, 2011 | 01:15 PM
daddyerne's Avatar
when i power the car on it cools and in 10 minutes it stops ,
Old Apr 26, 2011 | 01:16 PM
daddyerne's Avatar
to power it back on i need to power the car off, and back on for it to cool again
Old Apr 26, 2011 | 01:19 PM
TLDude876's Avatar
Chapter Leader (Houston)
Your ac compressor clutch and field coil might be out. Happened to myself as well as several members on here.
Old Apr 26, 2011 | 02:03 PM
jda123's Avatar
Dogmatic Dinosaur
You need to check the low and high side pressure with it running. If it is low on refrigerant, then it will stop when the pressure gets too low.
If the pressures are fine, then look at the clutch.
Mike Pilipenko
Mar 26, 2024 09:21 PM
SidhuSaaB
May 30, 2020 12:40 AM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
MikeJM310
Sep 24, 2015 07:24 PM
