A/C problem
A/C problem
i ahave a 2005 tl base and the a/c start to cont cool every 4 to 6 minuts i dont know what cant that b , my frien tel me about the thermostat of the a/c
Make MyTL Great Again
are you saying that the compressor comes off and on? that's normal?
are you saying it only works for 20 minutes then all 'cooling' ceases for good?
Dogmatic Dinosaur
You need to check the low and high side pressure with it running. If it is low on refrigerant, then it will stop when the pressure gets too low.
If the pressures are fine, then look at the clutch.
SidhuSaaB
05-30-2020 12:40 AM
