A/C No Pressure, Fan not Spinning...??
Old Oct 30, 2008 | 05:51 PM
99vtecaccord's Avatar
Last week my A/C was working fine.. blowing cold air as usual. A few days ago I notice the air wasnt cold. I checked the pressure and I had 0psi (prior to this a month before, I had 35psi). Also notice the radiator fan stopped kicking in.
So, what could by my problem? I dont understand how I can go from 35psi to 0psi overnight. Could it be a leak? If so, how will I be able to find out?
Old Oct 31, 2008 | 06:50 AM
Turbonut's Avatar
The only way it will drop pressure is due to a leak. Pretty good sized leak if it went out overnight though. You'll need to have someone put some gas in the system and then they can check for the leak. I use an electronic unit, some use an ultra violet light, dye can be used as well as soapy water if you're doing it yourself.
Old Nov 1, 2008 | 01:55 AM
hata_61's Avatar
ya and make sure you wear some gloves when you are putting the dye in. or else you'll have neon green fingers for a while. =)
Biggie_B
May 27, 2025 05:51 PM
F-C
Motorsports News
33
Aug 22, 2018 09:53 AM
SexyRL
4G TL Problems & Fixes
Aug 19, 2016 10:03 PM
iRaw
ILX Photograph Gallery
30
Aug 5, 2016 04:41 PM
hashbrown
Sep 29, 2015 12:13 PM
