Bumper grill
Old Feb 10, 2011 | 08:15 PM
BlueTypeSGuy's Avatar
Bumper grill
My bumper grill is kind of loose, so it's making a rattling that's audible in the car. I'm wondering what is holding on to the grills and what I can do to fix it. Thanks!
Old Feb 10, 2011 | 09:35 PM
stvtec's Avatar
'06 WDP TL 6MT
The grills in the lower fascia of the bumper? Are you sure that's what you're hearing from inside the car? I get a rattle from the center channel speaker which is a common issue. A bit of padding can resolve that one. I haven't heard of the grill rattling, and I'm a bit surprised if you'd be able to hear that.
Old Feb 11, 2011 | 04:11 AM
It sounds like something outside. Whenever I reach low speeds, at around 10-20 mph, it makes that sound. When I went outside, the passenger side grill is extremely wobbly. When I move it left and right, it makes hitting sound. I'll try to hold down the center speaker tonight.
Old Feb 11, 2011 | 08:42 AM
stvtec's Avatar
'06 WDP TL 6MT
Those lower grills are held in with 4 clips on top and 4 on the bottom. If you don't have the A-Spec front lip you can remove the lower grills very easily. Just have to reach in from the back and squeeze the clips and the grill will come out the front. In fact, here is a pic to make things super clear. You owe me for this one. lol You can just remove the lower grills and see if that makes the noise go away.
Old Feb 11, 2011 | 12:59 PM
I just checked the lower grilled. The grill itself is not loose, but the shiny metallic plastic piece is making the noise. Is it part of the grill or I can take it off without taking off the grill? What is holding that metallic piece? The noise is very low in the inside of the car, but with windows down, it's audible. It sounds like boiling water in the car. Also, if I was to take out the grill, is it easy to put back on, since they are squeeze clips?
Old Feb 11, 2011 | 07:30 PM
Very coincident thing happened today...I was checking the chrome trim on the passenger lower grill and it was moving and was thinking about taping it down to isolate the rattle. I went to a car wash and after the car wash, everything was freezing up. I was wondering where my rattle went, because initially I heard it, then it went away. Then after I got home, I realize that the water turned into ice on that chrome trim and it was impossible to move it. So I think that's definately where it's coming from. How do you remove that chrome trim?
Old Feb 11, 2011 | 08:33 PM
powerflow's Avatar
Wiggy Wiggy Wiggy
I think you need to remove the whole black piece from the bumper, then release the trim from the tabs. Something probably cracked or damaged. Should be able to glue back in place.
quanaman
Jan 9, 2023 07:33 PM
Acura604
2G RDX Photograph Gallery
27
Oct 8, 2020 09:24 PM
08KBP_VA
Oct 22, 2019 01:55 PM
iRaw
ILX Photograph Gallery
30
Aug 5, 2016 04:41 PM
rhdune16
Sep 28, 2015 11:31 AM
