Broken screw while replacing air filter
Old Mar 11, 2010 | 11:37 AM
WayneJay's Avatar
'06 TL 5AT NAV Anthracite
As I was tightening the screws on the air filter housing, one of them broke. Thought it was a bit odd as it didn't seem to be very tight when it broke. Anyways, I intend to get another screw and remove the broken piece, but I'm thinking the remaining three screws are enough to hold the housing in place. What do you all think?
Old Mar 11, 2010 | 06:48 PM
subinf's Avatar
One on the right for me
The remaining screws should be sufficient
Old Mar 12, 2010 | 06:01 PM
Adobeman's Avatar
The DVD-A Script Guy
You are probably OK for now but I'd fix it soon so that next time if another breaks you won't be down to two...which will be a problem.
Old Mar 17, 2010 | 02:43 PM
ЯάбzџяΐςђZ's Avatar
I had the same problem. Very little pressure caused it to break. It was ok with just the three screws. I still replaced it at the end of the month just for piece of mind...
Old Apr 12, 2010 | 09:11 PM
monank's Avatar
3rd Gear
how did you remove the screw? I just had the same problem.
Old Apr 13, 2010 | 12:49 AM
seoulja's Avatar
youll be ok. but if it bothers u that much.. u have to drill out the screw if its stuck in the houseing. find a drill bit that exactly matches the screw. be careful not to match the drill bit to the teeth of the screw. only the main part. drill it out and use a tap and die set to make new threads. and youll be fine. i used to be a acura tech for 10 years
Old Apr 13, 2010 | 07:57 AM
monank's Avatar
3rd Gear
sounds good. I'm gonna take care of that sometime before my next air filter change. Thanks.
Old Mar 18, 2011 | 09:44 AM
sam268's Avatar
Guess I am not the only one. I was trying to take mine off to replace the filter and broke the screw. The head of the screw bolt snapped off. Any one sucessfully got the rest of the screw out with a drill? what size bit did you guys use?
nanos
Nov 12, 2015 08:41 PM
Abe_Froman
Sep 16, 2015 01:27 PM
Aleax
Sep 9, 2015 08:04 PM
bymotion
Aug 31, 2015 05:00 PM
quake97
Aug 30, 2015 07:57 PM
