Broken Passenger Front Power Window
Old 02-09-2019 | 09:28 PM
Matthew Solc's Avatar
I drive a 2005 TL, bought it back in August. About a month after my passenger front window wouldn't roll up or down. I took it all apart, figured it was the window regulator, tore it out, and put in some wood to hold the window up until I got the replacement part.
Flash forward 6 months and I finally order the part. I get it all reassembled and window still doesn't go up or down. I tried replacing the fuse in case that was it, but it still did not work. What could be causing this?
Old 02-11-2019 | 12:02 PM
are you getting voltage at the regulator plug?
Old 02-11-2019 | 08:58 PM
I am. I went to a friend who does eletricele work and he said he would manually close the window by shorting the proper connection on the switch cable. He did, got a spark, and then almost nothing electrical works. No headlights, no brake, no blinker, no cluster lights or movement. I can't control any of the windows now, and my navigation has gone out, as well as radio and controls for my A/C.
Old 02-12-2019 | 12:02 PM
.he does electrical work but then idiotically blew a fuse? Find another more knowledgeable friend.. also check your fuses.
If you're saying you're getting power but the regulator isn't work, chances are you got a bad regulator. have you tried plugging it in not connected to the window to see if it runs on its own?
vw2xb
11-07-2016 12:09 AM
vito_ip14
06-13-2016 05:29 PM
UWMU
1G CL Problems & Fixes
11-10-2014 01:46 PM
BlackAce
1G TSX Problems & Fixes
15
07-12-2014 07:55 PM
goldbergm6
06-10-2014 01:44 PM
