Broken Passenger Front Power Window
I drive a 2005 TL, bought it back in August. About a month after my passenger front window wouldn't roll up or down. I took it all apart, figured it was the window regulator, tore it out, and put in some wood to hold the window up until I got the replacement part.
Flash forward 6 months and I finally order the part. I get it all reassembled and window still doesn't go up or down. I tried replacing the fuse in case that was it, but it still did not work. What could be causing this? |
are you getting voltage at the regulator plug?
(Post 16380703)
.he does electrical work but then idiotically blew a fuse? :doh: Find another more knowledgeable friend.. also check your fuses.
If you're saying you're getting power but the regulator isn't work, chances are you got a bad regulator. have you tried plugging it in not connected to the window to see if it runs on its own? |
