Brakes screeching...
Old Mar 6, 2006 | 10:50 AM
KJW73's Avatar
2014 RDX Tech AWD
Question Brakes screeching...
To schedule check-up or not to schedule check-up?
Does anyone's brakes screech? I've only had my car since November so I doubt the brakes are worn by now , but it has me wondering if the screeching is normal or not?
Since I previous "warped" (so-to-speak) my 04 Accord's rotors, I knew better to be hard on the brakes with the TL during the break-in period. So, I know it's not the rotors since there is also no steering vibration.
Any insight would be great! Thanks!
Old Mar 6, 2006 | 11:14 AM
Excelerate's Avatar
Former Sponsor
Is it a squeal? If so is it all the time or only when braking? Is it front or rear? On one side? It may just be that the pads are worn down and the metal tab (low pad indicator) on the pads is rubbing against the rotor and causing a squeal.
Old Mar 6, 2006 | 11:44 AM
levon1830's Avatar
I get break squeal for the first few stops after my car has been sitting for a long time (like 6-8 hours), then it goes away. I have also wondered whether or not this behavior is normal. I have not had a chance to search the forum yet, so I don't know if this has been discussed before.
Old Mar 6, 2006 | 12:19 PM
KJW73's Avatar
2014 RDX Tech AWD
Thanks for the feedback!
It's a high-pitched sqealing/screeching noise that happens when I brake; it doesn't appear to happen when I'm not braking, but it does happen often when I am braking. I assume it is from the front of the car, but I don't know if one side or both sides?
I just hate to imagine my pads being worn with only 2,700 miles and having only owned the car since November 16th...
Old Mar 6, 2006 | 12:23 PM
drdamian's Avatar
FOR SALE - BM
maybe there is dirt or something... i would take it back to the dealer and make them replace it... noway should they be worn out by now.
Old Mar 6, 2006 | 12:46 PM
Nandito28's Avatar
do you have a MT (brembos)? If so....
I had this problem...The "I need new brakes sound" and the "old car" squeal sound...all of which are covered under warranty....they shouldn't be making any noise at all!!!
Acura does have a Bulletin out for it as well...you shouldn't have any problem with them fixing it...even if they can't replicate the problem.
i wouldn't know about automatics
Old Mar 6, 2006 | 01:03 PM
KJW73's Avatar
2014 RDX Tech AWD
I have the automatic...
Just thought I'd check in to find out if this occurs with other TL's....
It is due for inspection by the end of March, so when I take it to the dealership, I'll have them take a looksee then. Hopefully, it's nothing.
Thanks!
Old Mar 6, 2006 | 01:06 PM
Nandito28's Avatar
^my bad, I just now saw your signature....Still shouldn't be making any noise...good luck with that.
Old Mar 6, 2006 | 01:12 PM
gqchicago's Avatar
5mins2disney.com
I bought my '06 in mid-September and it has 4300 miles now, and the brakes have never squeaked even once, this is not normal, I'd get it checked.
Old Mar 6, 2006 | 01:13 PM
KJW73's Avatar
2014 RDX Tech AWD
Thanks!
One things I'm learning about new cars is that they aren't perfect (from my own experience and from this Board)...
... my previous new 04 Accord had a terrible rattling when I took it off the lot...the windshield needed to be reset/readjusted....so, I've just accepted that shit is going to happen.
Thanks again!!
Old Mar 6, 2006 | 01:15 PM
pkim05's Avatar
I had a similar problem. Sounded like my brake pads were worn out, but it couldn't have been cuz my TL was still pretty new. It didn't happen everytime I pressed the brakes, but it happened enough to make it a concern. So I took my car into the dealership and they "deglazed" it, but that only worked for a few days. So I took it back and they replaced my front brakes. Hope that helps.
Old Mar 6, 2006 | 02:19 PM
KJW73's Avatar
2014 RDX Tech AWD
Acura's "aware" of problem...
I called the dealership to make an appointment for my inspection, emissions test and oil change for next Friday and when I mentioned about the "screeching" coming from the brakes the service rep told me that they are aware of the problem and that they frequently receive complaints from TL owners. The dealer said it is nothing to be alarmed about; it's just the brake dust piling up (as someone else eluded to) and that Acura is researching to remedy the problem.
Old Mar 6, 2006 | 02:42 PM
hank1105's Avatar
I am having the same issue with 5200 miles on my 05 TL auto. Dropping off my car tonight at Curry Acura. This will be the first time I will be bringing in my car for service, we shall see how it goes. I just hope they fix the issue the first time, I don't have time to go back and fourth, will find out tomorrow.
Old Mar 6, 2006 | 03:35 PM
KJW73's Avatar
2014 RDX Tech AWD
Keep us posted!
...and good luck to ya!
Old Mar 7, 2006 | 06:52 PM
TLTrance's Avatar
AVB for President!
This is exactly what I experienced very recently. The dealership found that the front right brake was squealing due to the development of a hard spot on the brake pad. I was told that this can happen due to normal wear and tear which results in the ceramic material to fuse or weld together at various points on the pad. Either way, their solution was to give me new brake pads, as well as resurface the rotors, all for free of course.
Essentially I have close to new front brakes (they replaced the Driver front side pad as well, to even things out), with the exception that I'm not starting with new rotors (resurfaced). This outcome was better than I expected.
I have a 2005 5AT.
Old Mar 8, 2006 | 08:20 AM
hank1105's Avatar
Got my car back last night, great service overall. The issue was "glazing" of the rotors, so they deglazed them and did not install new pads. As of now there isn't any noise when braking, but we shall see what happens in a few weeks. Service was very good, this was Curry Acura in White Plains, NY
Old Mar 8, 2006 | 07:24 PM
mbwmn's Avatar
next time you get squeeling on application try a few (3?) higher-speed (50mph+) brake applications on a deserted road. each time should be progressively harder/faster. this will probably break the "glaze" (from repeated light applications) and save you a trip to the dealer.
Old Mar 8, 2006 | 08:32 PM
JERU's Avatar
Yeah, I got the same thing with my Brembos, and the Service department told me that it happens with people who brake lightly. They recommended some hard braking a few times should alleviate the problem. I have to admit it did eventually stop. The Brembos are notorius for this, I don't know about the regular pads on the AT. Couldn't hurt you to try a few times, may help you out
Old Mar 9, 2006 | 09:52 AM
hank1105's Avatar
Good to know, I haven't hard braked the car as of yet, good to try to see how it handles. Thanks.
Old Mar 9, 2006 | 12:03 PM
Ramairgt1's Avatar
Miss you :(
I have the same problem and plan on getting it looked at
Whether it works or not you should never have to slam your brakes on at 50+ mph to fix this problem, thats the biggest BS i have ever heard.
Old Mar 9, 2006 | 08:38 PM
Nandito28's Avatar
You shouldn't consider that normal...braking harder shouldn't be the solution.
I had the squealing and the I need new breaks sound as well 05 TL MT (brembo)...they gave me new pads the first time and resurfaced the rotors, which made it worse, the second time they gave me "new design 2006 rotors" (as the service guy put it) and pads....I haven't heard anything at all (even during soft braking) and its been about 1K miles since I got them
point being...even if they're brembos they shouldn't make any sound. The dealer shoudln't be saying "brake harder"!
this comment is only if you are still braking hard to get rid of the noise...if not than disregard
all of my work was under warranty w/ no hassle whats so ever.
Old Mar 11, 2006 | 04:03 AM
ed99's Avatar
9.5+10.5 22m=Hella Flush
Alot of members seems to have the same problem. I had the same problem and brought it back to Acura at no charge. The service manager told me the cause was the brake pads. High performance brake pads are harder and will tend to squeal.
Old Mar 12, 2006 | 08:40 PM
mbwmn's Avatar
WHERE in this thread were you or anyone else instructed to "slam your brakes on at 50+"?????
""next time you get squeeling on application try a few (3?) higher-speed (50mph+) brake applications on a deserted road. each time should be progressively harder/faster. ""
Old Mar 13, 2006 | 06:42 AM
Ramairgt1's Avatar
Miss you :(
i misread your post..ive seen other members say to slam your brakes on at 50....you shouldnt even have to brake "hard" at 50+ to fix this problem...that like telling me to drive my car off a cliff to fix my rattles
GWEEDOspeedo
Jan 15, 2016 10:39 PM
lanechanger
Oct 13, 2015 10:56 AM
rockyboy
Oct 2, 2015 10:45 PM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
2ManyHobbies
Sep 24, 2015 09:23 PM
