Brake Pad & Rotor Thickness Replacement Recommendations
Old 05-13-2015, 09:11 PM
Fearless DIY Guy
DeathMetal's Avatar
What are the measured thicknesses you're allowing the pads and rotors to draw down before replacing?
Old 05-13-2015, 11:22 PM
Registered Bunny
polobunny's Avatar
Received 1,073 Likes on 892 Posts
I'm going to do my first brake job on my TL this weekend. SM rotors specifications are 26mm AT front, 23mm MT front and 7.5mm rear. Brake pads thickness 1.6mm both front and rear. For anyone other than myself I would not go under... but let's just say my rear pads are toast and well under minimum thickness...
DeathMetal (05-14-2015)
Old 05-14-2015, 07:00 AM
Turbonut's Avatar
Rotors:
A/T non TL-S max refinishing limit 26.0 mm 1.02"
M/T and TL-S max refinishing limit 23.0 mm .91"
Pads:
Minimum thickness F/R .06"
Old 05-14-2015, 09:48 AM
Fearless DIY Guy
DeathMetal's Avatar
Thanks, guys.
mada51589
05-03-2022 08:54 PM
mav888
1G RDX (2007-2012)
09-08-2015 11:49 AM
nishant11
09-02-2015 10:34 AM
Quick Reply: Brake Pad & Rotor Thickness Replacement Recommendations
