Blown Fuse??
Blown Fuse??
If my fuse is blown, do I have to buy them from the Acura dealer or can I just get them at a local auto store or even walmart? Will the aftermarket fuse do any harm to the car? How will I know which fuse to buy. The manual said that I need a 20A fuse for my front fog lights. (I have a 2004 Acura TL). Any suggestions would help. Thanks.
Just replace with the same size and type of fuse that came out in the first place. You can get them anywhere.
The bulb? Is one or both out?
Chapter Leader (NY/NJ)
Once something has been modified, now who knows what went wrong... could be a short, a ground, improper wiring, a fuse, bulbs. anything..
did you do the work yourself? do the leds work? did they cut the wire that goes to the connector? is the bulb even plugs in??
I had the work done AckTL05. He spliced part of the OEM fog wire and connect the LEDs to it. So the HID fogs on the bottom is running through factory wire, but the LEDs is connected to the middle part of the wire from the OEM fog circuit. So when the fogs are turn on the LEDs turn on with it.
You need to go back to your installer and have him take a look at it.
you drove from MA to NJ for leds and lower fogs??
PM ACK05TL, hes good about responding to issues and since he did the work, he"ll have a better understanding of what might've gone wrong.
my suggestion, check all splices and cables..
Unsubscribed..
Unsubscribed..
Acura604
20
08-05-2017 12:55 AM
xsilverhawkx
09-28-2015 06:51 PM
ripit
09-26-2015 06:19 PM
