Battery died and no option for radio code input
Old Mar 20, 2015 | 10:47 PM
jasont49's Avatar
My battery died while I was away for a week and brother didn't keep my car running like I asked him to so my battery died. When I got the better back up and running I expected that I had to put in the Navi code and radio code. The Navi code input option was there but there is no option for me to put the radio code in. I tried pulling the fuse for it but that didn't work. Any suggestions? ?
Old Mar 20, 2015 | 11:33 PM
Hi speed's Avatar
runnin a little boost
Pull the battery cable for 10 mins and that should reset the system. I know you have to use different buttons to input the code for the radio.
Old Mar 20, 2015 | 11:45 PM
TLifestyle's Avatar
press the volume/power button and it will allow you too put in your code...hope this helps
Old Mar 20, 2015 | 11:52 PM
jasont49's Avatar
Ok trying the battery one now
jasont49's Avatar
Tried that and nothing happens
Old Mar 21, 2015 | 12:00 AM
TLifestyle's Avatar
it doesn't show up on the nav screen, it shows code on the disply for the clock.....press power and then just key in your code and then you should be fine
Old Mar 21, 2015 | 12:09 AM
nfnsquared's Avatar
IIRC, the procedure in this case is to pull fuse #7 for one minute, then try it again.
Old Mar 21, 2015 | 12:10 AM
jasont49's Avatar
Pressing the power button doesn't so anything..
jasont49's Avatar
Tried that and didn't work..
Old Mar 21, 2015 | 12:14 AM
jasont49's Avatar
But just so I'm sure you're talking about the fuse under the dash right?
Old Mar 21, 2015 | 12:16 AM
TLifestyle's Avatar
Yes it does, only nav code automatically pops up, you need to "turn on" your radio for it to be like.... code first please... lol
Old Mar 21, 2015 | 12:17 AM
jasont49's Avatar
Normally yes, but in this case it's not working...
Old Mar 21, 2015 | 12:29 AM
nfnsquared's Avatar
Yes, are you sure you pulled #7? If you're not careful, it's easy to mis read the rows of fuses.
Old Mar 21, 2015 | 12:30 AM
jasont49's Avatar
Yeah I'm sure. The fuse doesn't look to be blown either
Old Mar 21, 2015 | 10:34 AM
truonghthe's Avatar
Is your radio turn on? Once you have the radio turn on enter the code via radio preset button.
Old Mar 21, 2015 | 11:05 AM
jasont49's Avatar
The radio doesn't turn on. I've tried disconnecting my battery for 10mins, iv tried pulling fuse#7(fuse isn't blown either) for a min, and yes iv tried pushing the power button lol. Nothing seems to be working...
Old Mar 21, 2015 | 11:12 AM
truonghthe's Avatar
Can you take a video for us?
Old Mar 21, 2015 | 11:21 AM
NBP04TL4ME's Avatar
Stay Out Of the Left Lane
Do you have Nav? Curious what shows when you have audio displayed on Nav and you hit power.
Old Mar 21, 2015 | 11:25 AM
jasont49's Avatar
Yeah I have nav. But when I try to hop to the audio through that, nothing happens
Old May 1, 2015 | 04:20 PM
DoggieCombover's Avatar
Probably not all fuses are the same, rather than pull a specific number, pull the fuse that is for ACC. That did it for me
Old May 1, 2015 | 04:21 PM
That would be the fuses under the hood, not under the dash...
Old May 16, 2015 | 07:00 PM
Timbert's Avatar
I don't have navi but on the radio itself when I power up after battery disconnect it prompts for the code. I think you only get four or five tries, maybe your bro tried that too many times and now it's bricked, and that's why the radio doesn't come on at all?
Old May 17, 2015 | 10:17 AM
quantum7's Avatar
Had similar issue after a dead battery. My problem was the fuse. Replaced and problem solved.
mada51589
Jan 9, 2025 04:40 PM
cycdaniel
Dec 17, 2019 10:58 AM
gemz_acura
4G TL Problems & Fixes
15
Sep 26, 2015 06:12 PM
ninersfgiantsfan
Sep 9, 2015 01:14 PM
jordanboi
Sep 5, 2015 01:33 AM
