Auto climate control blowing cold mostly, faulty air temp Sensor?
Old Sep 28, 2018 | 11:08 PM
Octanee's Avatar
Hey guys, as the title says I'm wondering about a faulty air temp Sensor? I say that because if I take it off auto and go to max heat I seem to get heat, but when I let it sorta do its thing, I can set. It to 26C or 28c and it'll blow cold, and at like 24c it'll Maybe have the ac going, meanwhile it's like 15c or less outside now.... So all summer no issues but now that it's.getting old... The cars staying cold!
Could be a blend door but not sure which way to go with this. Thanks!
Old Sep 29, 2018 | 07:32 PM
redbeard1's Avatar
If I read your post correctly, it says you have heat and cold but your automatic temperature controls don't seem to control the temperature of the air that comes from your vents.If so, it could be your air mix motor/cable is not working. To check, turn on your car and have a buddy click the temperature button for the AC from Low (57 degrees) to High (85 degrees). If you look at the area highlighted in the attached image, you should see a lever move slightly each time your friend increases/decreases the temperature.
Usually, when the motor/cable is not working well, increasing the temperature will do nothing to that lever. Then after a set number of clicks (for example from 58 to 77), the lever will move a lot. This means the problem is either your mix motor or the cable.
Many have had success with cleaning the motor. You can run the diagnostic, but my diagnostic had no codes, even though my motor was bad.
https://acurazine.com/forums/3g-tl-p...-motor-956659/
Last two images come from this thread
https://acurazine.com/forums/third-g...ve-diy-747304/
Old Sep 29, 2018 | 08:02 PM
Octanee's Avatar
Wicked, thanks for the info, I'll check into it, it could very well be that as your saying, I was unaware the car had a flap/cable controlling coolant into the heater core, I figured my blend doors must be physically working just fine considering It does get heat, but just not finely. Will check into it tomorrow when I have the car and report back. thanks!
Old Sep 30, 2018 | 10:15 PM
Octanee's Avatar
update: I tested the functions tonight and got no codes.... When doing the temp sweep the actuator/cable/valve open from closed to open, However going from "low" to 1 point up, it goes from fully closed to fully open. I'd imagine low would entail maximum a/c operation/temp so makes sense to fully choke off the coolant flow. That being said I don't see that as being my issue for temp, The diagnostics never spat me out any numbers or anything, So i assume its fine, interestingly it seemed to be working OK tonight.... hmm....
Old Oct 1, 2018 | 12:12 AM
redbeard1's Avatar
Originally Posted by Octanee
update: I tested the functions tonight and got no codes.... The diagnostics never spat me out any numbers or anything, So i assume its fine, interestingly it seemed to be working OK tonight.... hmm....
I ran the diagnostic many times and never got a code. Yet my mix motor was bad. Cleaning did not fix it, so I checked the resistance according to a method in the service manual. That method told me my motor is out of spec by a lot.
With my motor, when I start on Low and click up, the lever under the hood will not move until my temperature reads 83 degrees. At 83, the lever will move a lot. So my car blows really cold air even at 82 degrees. At 83 degrees, the air gets warm. At Max, my air is hot.
Old Oct 1, 2018 | 08:43 AM
Octanee's Avatar
Interesting, so in theory it shouldn't move full tilt one click up from low on the temp control, I'm going to keep an eye on it now but at least I got heat I suppose 🤷
Old Aug 30, 2024 | 03:29 PM
ROKET's Avatar
Friend, tell me, did you solve this problem? What was the reason?
piggydog
Apr 28, 2013 05:35 AM
Magnusvermagnussen
1G RL (1996-2004)
Apr 9, 2009 11:13 AM
cd5-obsession
Jul 12, 2008 10:54 PM
paautoxer
Jul 24, 2006 08:58 AM
FlyingPig
Mar 31, 2001 12:35 AM
