PS pump some tests
Old Sep 4, 2024 | 02:40 AM
mariusz439's Avatar
PS pump some tests
As many of us I had problem with PS pump. No whining but very little power.
Two or three year ago I did complete reseal. Had feeling it helped a little but one year ago the the pump stopped supporting the steering completely - it worked without any wining.
Did complete flush even with cleaning formula. Didn't helped.
Ordered new Maval pump from rock auto. Changed in April and the steering started to work as it should. However it started to leak in June.
As I had some thoughts about valves which were not addressed anywhere and having two pumps, I started some tests.
1. I cleaned the both valves in the old pump as I did not when resealing - it didn't fixed the old pump.
2. I switched the valves from working pump to the old one - it didn't fixed the old pump.
So final conclusion is the not working PS pump is not the matter of PS pressure switch, seals, valves (main and supporting).
BTW. I ended with moving the bearing and the seal underneath from my old pump to Maval and it seems the leakage stopped.
kap1320
Jun 8, 2018 11:47 AM
MyKids&Cars
Apr 14, 2014 09:10 AM
twill220
Apr 16, 2013 01:25 PM
silvervtec96
2G CL Problems & Fixes
Jul 12, 2010 07:42 PM
ferizzo
Mar 18, 2009 11:04 AM
