02 auto climate control won't maintain temp
Old Jul 22, 2006 | 07:29 PM
paautoxer's Avatar
The climate system doesn't maintain a set temperature in my 02 TLS. If I set it at 70 degrees, it usually blows cold, like it is set at 60 degrees. To get the temp up to an actual 70-degree temp I have to raise the temp setting to 80+…..then after a few minutes at the 80+ setting the temp blows an actual 80+ and I have to run the temp setting back down to 60 to get an actual 70 temp. Very distracting while driving
Anyone have this problem before? I hope it's an easy (and cheap) fix!
Old Jul 23, 2006 | 10:25 AM
rego's Avatar
Yep, same problem here and same solution. Yep, very distracting and solution doesn't always work well. I just turn it up and turn it down and turn it up and...
Old Jul 24, 2006 | 08:58 AM
paautoxer's Avatar
We can't be the only two in the country with this problem. Does anyone out there have a fix? When my car was under warranty, the dealer (Hopkins Acura, Redwood City CA) said they wouldnt' know where to begin to fix the problem.....not a confidence-inspiring deler, to put it mildly.
Dec 7, 2020 05:39 PM
Rachel Lu
Sep 27, 2015 09:53 AM
Rob144
Sep 21, 2015 08:18 AM
lovic87
Sep 15, 2015 06:07 PM
PortlandRL
Sep 14, 2015 12:01 PM
