Climate Control Blowing Cold when at Idle
Old Apr 2, 2009 | 02:57 PM
Magnusvermagnussen's Avatar
Been having trouble lately with my climate control.
When I'm at idle, no matter what heat setting I have my car at, it blows cold- warm at first, but then over about 10 seconds, it goes from the normal setting to absolute cold.
A/C doesn't seem to have been affected. this only seems to happen when the car is at idle- when I put it into neutral and give it a little gas (say up to 1,500rpm), then the heat comes back onto the setting I had it at.
The problem seems to go away over time (i.e. if I take a big trip over an hour or so).
Any thoughts before I take it to a mech and spend $200 to get it diagnosed?
Thanks!
Old Apr 2, 2009 | 07:32 PM
Ken1997TL's Avatar
Change the coolant and thermostat
Old Apr 3, 2009 | 11:13 AM
Wow. Do I ever feel like a goof. That was the easiest 'fix' in the world.
I just topped up the coolant and it's fine now.
Thanks for the heads-up!
Old Apr 3, 2009 | 11:21 AM
Ken1997TL's Avatar
Make sure you bleed the system for any air pockets that might get trapped.
I had the same problem not too long ago.
Old Apr 9, 2009 | 11:13 AM
prs2008RL's Avatar
ya right....i had the similar problem long back....i flushed the system, replaced the radiator hose and now it is ok
blacktsxwagon
Oct 27, 2015 10:12 PM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
Kres43
1G RDX (2007-2012)
Oct 3, 2015 07:16 PM
mdlex389
4G TL Problems & Fixes
Sep 28, 2015 06:29 PM
Brandle34
Sep 23, 2015 07:20 PM
