Anyone know the sequence for a resetted ECU
Old Mar 24, 2011 | 09:43 PM
jamesl5385's Avatar
I need to complete a smog check but I just remembered that I changed my battery had died a week ago. I was wondering if anyone knew the sequence to complete the following. I got it smogged yesterday and I failed due to a OBD catalyst-not complete and an OBD EVAP- Not complete. Thanks
Old Mar 25, 2011 | 01:55 AM
libert69's Avatar
18psi
I had all this info written down but I have no idea where it is. If you drive about 50 miles hitting various speeds throughout the course of the drive youll be good to go. Do some highway and city driving mixing up your speeds and cruise at different speeds for a few minutes
Old Mar 25, 2011 | 11:54 AM
jamesl5385's Avatar
I have driven for over 200 miles doing so. Still can't get it to clear.
Old Mar 25, 2011 | 12:28 PM
Will Y.'s Avatar
Registered but harmless
Are you trying to clear a Check Engine light or dash trouble light?
If so, that's different from setting/resetting the ECU, which for the TL refers to the factory vs. adaptive engine/throttle/transmission settings controlled by the ECU.
Old Mar 25, 2011 | 12:50 PM
nfnsquared's Avatar
No, he's referring to setting the Readiness Codes. Takes at least 3 days to set. There is a procedure to expedite the process.
OP, RTFM....pg. 243/263
Old Mar 25, 2011 | 12:52 PM
sddale's Avatar
If you just replaced the battery and there hasn't been a CEL then you will have to drive until the there is enough data saved regarding emissions. The information probably got erased when you changed the battery...similar to if you reset a CEL the information would have to accumulate for the reading. I have been told it could take 500 miles.
Old Mar 25, 2011 | 01:24 PM
Bearcat94's Avatar
AZ Community Team
Typo?
Page 348 & 349 in mine.
Regardess, it's in the OM.
Old Mar 25, 2011 | 01:30 PM
jamesl5385's Avatar
So the sequence is in the OM? I'll have to look at mine.
Old Mar 25, 2011 | 01:39 PM
nfnsquared's Avatar
Originally Posted by Bearcat94
Typo?
Nope, page #'s are correct for 04 OM. Hmmm. Only 270 pp in the 04 manual. Wonder what's been added for the 07??
OP, search the index for "Readiness Codes"...
Hehe, yeah, if only every poster realized this before posting....the site would be 1/3 the size....
Old Mar 25, 2011 | 02:06 PM
Bearcat94's Avatar
AZ Community Team
.... Wonder what's been added for the 07??
They had to add all the TL-S specific stuff. In some cases I know it's several pages on a topic. Not sure if that accounts for all the page difference, but certainly some of it.
I hadn't thought of that. But I was perplexed why your were referencing the "fuel guage" page (or whatever it was in my OM).
Old Mar 25, 2011 | 02:08 PM
Will Y.'s Avatar
OIC.
First addressed on p. 253 of the slightly lengthier '05 manual, but OP has an '06.
Regardless, it is referenced in the manual's index.
Old Mar 25, 2011 | 04:03 PM
sddale's Avatar
In the 06 manual its on pages 257 and 277
Old Mar 25, 2011 | 09:41 PM
jamesl5385's Avatar
Cool found it. Was wondering though. Could I do all the sequences all in one engine start or do I need to do them separately?
Let car sit for 6+ hours
Car have 3/4 tank
Outside temp between 40-95 F
start car let idle for 20 secs
keep in park and rev engine to 2k RPM for 3 mins
Travel highway for 20 minutes going 50-60 MPH (thats slow) & drive 90 secs without moving pedal.
drive city for 10 mins & let coast a couple secs without applying gas or brake.
Old Mar 25, 2011 | 09:57 PM
nfnsquared's Avatar
^^^ I say one...
Old Mar 26, 2011 | 03:03 PM
jamesl5385's Avatar
Thanks everyone for the info. Got everything cleared up and good to go. Thanks again.
brboy
Oct 5, 2015 11:34 AM
Skirmich
Oct 1, 2015 12:59 PM
malvothegreat
Sep 29, 2015 12:38 AM
Froid
Sep 27, 2015 06:16 PM
ceb
ILX
Sep 27, 2015 10:56 AM
