Any idea what this fluid leak/drip is?
Hi, I noticed these dark yellow/brown drops on my driveway where my kid parks her 08 TL. The drops are approximately around the front passenger side. Any guesses? A bit of research suggests it might be brake fluid. I checked the brake fluid level and it's halfway between min-max. Then again, I don't think that I would notice a significant drop in brake fluid with just this amount of dripping - so could be minor or just starting. I've got it in the garage now with a piece of cardboard to see if it's still leaking/dripping. But while I'm waiting - I thought I would see if anyone else had any thoughts/ideas?
If it's coming from the passenger side and brake fluid, it could be the VSA modulator. The brake master cylinder and reservoir are on the driver's side.
It could also be power steering related with the p/s fluid reservoir on the front passenger side.
@Zeta - Thanks I'll do some research and check P/S fluid too. There was an error message last month about VSA 61, which seemed to be related to low battery voltage. We were having problems keeping her battery charged, but that turned out to be the hands free unit failing. Maybe related / maybe coincidence.
oil pump leak. mine's been doing this for four years, just keep an eye on level and top off until you can do a major service, plus my car is a piece of junk. i just keep a metal drip pan on that passenger side to collect
Mack454SS
04-09-2004 07:42 PM
