Brake Fluid
Old Apr 13, 2006 | 12:36 AM
chiznizle's Avatar
Brake Fluid
What's Up, I noticed the brake fluid swishing around in the Resevoir, Is this Normal? Looks like it goes through some kinda cooling system maybe.
Old Apr 13, 2006 | 07:21 PM
TexasHonda's Avatar
Brake fluid movement in reservoir should be negligible. When you press the brake you compress fluid already in the brake lines which does not compress easily. Only fluid that gets into the brake lines is additional fluid to expand the caliper pistons as the brake pads wear,...very slow gain of fluid. I've never heard of reverse flow.
ABS modulator might send some fluid into the system on initial startup, but I don't know this to be the case.
good luck
Old Apr 15, 2006 | 12:20 AM
chiznizle's Avatar
my bad I meant the power stearing resevoir, it was a long day when I posted that thread. Any comments?
Old Apr 15, 2006 | 08:26 AM
TexasHonda's Avatar
Normal for PS fluid to be circulating. It's continually being pumped and returned to reservoir.
good luck
SidhuSaaB
May 30, 2020 12:40 AM
acuratl26
Apr 23, 2020 07:30 PM
LeVeL
Oct 18, 2015 04:19 PM
lanechanger
Oct 13, 2015 10:56 AM
ROSSARONIE
Sep 22, 2015 11:46 AM
