Anti-Theft Issue
Old Sep 27, 2016 | 07:39 PM
PeaTearGriffen's Avatar
5th Gear
Anti-Theft Issue
I have a 2006 Acura TL and left it sitting for two weeks. When I got back my cars battery was dead. When I hooked up the battery to a charger the anti-theft alarm went off. I finally got the alarm to stop going. I was able to turn the car on, however the car wont shift out of park. I used a flat head on the little area by the shift knob in order to force it into gear. I drove the car around and it responded differently when I would step on the gas. Thoughts?
Old Sep 27, 2016 | 08:07 PM
wackjum's Avatar
Acuras do strange things when they have a low/weak battery. I would change the battery first. I can imagine how a weak battery might affect the electronically controlled transmission.
Old Sep 27, 2016 | 08:08 PM
AZuser's Avatar
_
What do you mean by "it responded differently when I would step on the gas"?
"Differently" how?
Old Sep 27, 2016 | 08:27 PM
5th Gear
"Differently" how?
The car would kind of lag a little bit when I would accelerate. Very different then before.
Old Sep 27, 2016 | 08:30 PM
5th Gear
Yeah I am going to have to get it charged. The thing is I just purchased this battery two months ago and it couldn't hold charge for two weeks. I think I might have a draw coming from somewhere.
Old Sep 27, 2016 | 08:37 PM
Oh Sickest TL's Avatar
Jeff
when the battery dies or is reset the transmission has to undergo a relearn process. Its called grade logic . give it some more time and see how it responds in a week or so
Old Sep 27, 2016 | 08:38 PM
AZuser's Avatar
_
Maybe the ECU got reset when car lost all power.
It's said that if you disconnect the battery (or have a dead battery in your case ) for a bit and then reconnect, the ECU resets and has to relearn everything.
https://acurazine.com/forums/3g-tl-p...-cable-588978/
https://acurazine.com/forums/third-g...hanges-631749/
https://acurazine.com/forums/third-g...-happy-747662/
Do as Oh Sickest TL said and drive the car for a while and see how it feels after a week or 100 miles or so.
Old Sep 28, 2016 | 10:55 PM
Hi speed's Avatar
runnin a little boost
Check out your Bluetooth to see if it's working. It's know to go bad and drain the battery to the point of ruining it.
Old Sep 29, 2016 | 12:01 AM
5th Gear
Yeah my Bluetooth doesn't work at all. Any recommendations on how to make it stop draining the battery?
Old Sep 29, 2016 | 12:16 AM
Jeff
remove it
Old Sep 29, 2016 | 12:31 AM
5th Gear
Originally Posted by Oh Sickest TL
remove it
Yeah just looked up how to do it. super easy. Haven't gotten the chance to charge the battery yet, but im definitely going to do so soon. Unfortunately, I still can't get out of park. Hopefully charging the battery to full charge will solve the issue because the battery cant hold a charge right now. the car only starts when i have it plugged in.
Old Sep 29, 2016 | 07:54 AM
alexb92's Avatar
Your battery is clearly defective. Since its new, just go get it warrantied. I can almost guarantee you it will fix your weird issues. TL's are very sensitive to bad batteries, and it can cause some really strange issues.
Old Sep 29, 2016 | 08:04 PM
DMZ's Avatar
DMZ
Head a da Family
chickdr
Mar 12, 2017 09:58 PM
dhm118
Jun 2, 2016 07:14 PM
unnamedny
ILX
18
May 9, 2016 08:19 AM
bpenn627
Feb 7, 2016 07:41 PM
teggymike410
Feb 3, 2016 06:44 PM
