Airbag MIL/warning light... SOMETIMES
Old Oct 14, 2024 | 11:46 AM
B Sc's Avatar
Ok, the Autel OBDII has more capability reading sensors, than there were sensors back in 2004 when this TL was made. So baffled a bit.
The airbag warning light (drivers instrument panel) sticks on after the warning light test on startup is done and all the other lights fade out.... SOMETIMES, very rarely.
The OBDII device doesnt pick it up as an issue or MIL or anything... so, how can that be?
And of course it doesnt stay stuck for the next couple dozen start ups, so very hit/miss/erratic/irregular...
Anyone have experience with this wierdness, and should I not gafk?
Old Oct 14, 2024 | 11:57 AM
peter6's Avatar
What Autel do you have? Can you communicate with ABS and gauge cluster?
Old Oct 21, 2024 | 12:48 PM
B Sc's Avatar
no MIL indicators on Autel
Its an Autel 417. Doesnt show a dedicated ABS scan but it DOES do guage cluster and a list of many MIL indications it can detect, and reset. The ABS MIL on the dash only shows up in the startup sequence and goies out, so trusting the car the ABS is fine, and actual physical test it does what ABS is supposed to do.
Old Oct 21, 2024 | 01:17 PM
vpasla1's Avatar
Might be the seat belt buckle. Can cause the light when buckled.
Try to wait to buckle after vehicle started and all lights cleared to see if it pops up.
Old Dec 9, 2024 | 02:17 PM
B Sc's Avatar
well tried it and didnt make the difference... SOMEtimes... would be belt, park brake acronym icon and the bag.
Belt off when I belt up, brake icon off when i release it, SOMEtimes the bag light stays on... in that order.
Im thinking about a newer model Amish 2hp buggy now... (sarc)
Old Dec 11, 2024 | 12:24 PM
mvl's Avatar
mvl
Every time I had an SRS light on my RSX, it was a sign that the battery was about to die within a month. Startup voltage was insuffficient for the SRS computer to start up properly.
How old is your battery? If over 4 years is will probably die soon anyways to might be easier to just replace it to rule out voltage issues.
Old May 24, 2026 | 10:14 AM
DUCRDX's Avatar
Strike Hold
Did you ever figure this out? Starting to happen to mine now. I replaced the battery only a few months ago, but will check the voltage.
Old May 25, 2026 | 02:56 PM
B Sc's Avatar
no clue sorry
like title says, no clue. Its a nice surprise, sort of, when things 'fix themselves' but then again I prefer to know what was the problem that caused in the first place.
There is nothing that I can think of that was done before/after that could relate to this sudden light appearance. Deer accident, new battery install, all sorts of major things not related were before this light came on.
I had forgotten about this issue too... shows how long its been since it cropped up again.
Only slightly bothersome reoccurring issue now is the O2 sensor... SOMEtimes... cleared it with OB2 after playing with the wiring/harness/contact spray cleaned anything reached for THAT problem, and that problem went away back then. Dont think its at all possible that taking off the harness connector for that bank (2 sensor 1 I think... the one RIGHT BESIDE the rad and so easy to reach), would have anything to do with it. Did that harness clean/reconnect only months ago, airbag dash light has been so long before that, dont recall when
Old May 25, 2026 | 02:59 PM
B Sc's Avatar
battery was either 2 or 3 yrs old at the time I posted this airbag issue, still have the same battery working fine ... issue didnt come back now for so long forgot when it 'stopped'
Suppose I should find a way to test the airbag bulb, maybe force a trigger with a fuse pull or harness disconnect, just to make sure the bulb still works... not that it makes sense it would lite up if 'failing'
Old May 26, 2026 | 09:28 AM
DUCRDX's Avatar
Strike Hold
Thank you, I appreciate the response. I was contemplating taking it in to the dealer to check out, but the nearest one is a ways away. I'll see if it just disappears on its own.
Old May 26, 2026 | 08:54 PM
csmeance's Avatar
bulb should show up upon startup so look for it in the speedometer
ohbabbbay
Nov 10, 2024 10:00 AM
Oh1TypeS
Jan 21, 2008 07:33 PM
arjjra
1G TSX Problems & Fixes
Nov 30, 2007 04:51 PM
wasup1357
Oct 9, 2006 02:21 PM
nycvr6
Aug 21, 2001 07:23 PM
