Additonal parts replaced along with clutch/flywheel?
Subscribe
Apr 19, 2018 | 04:18 PM
Going to buy clutch/flywheel from rockauto. Was wondering what else i should replace with the clutch. I saw that it is recommended to replace the rear main seal. Could somebody link me to the actual part (preferably on rockauto) or if its even necessary?
@159k 07 tls
Reply 0
Apr 19, 2018 | 08:05 PM
Pilot bearing if not included
Flywheel-depending on condition
Look under engine-crankshaft seal
Make certain there's no leaks, master, slave, or hose
Reply 0
Apr 20, 2018 | 06:08 AM
thankyou.
i think the clutch kit comes with pilot bearing and i plan on getting the flywheel as well since its only $170. My slave cylinder (with cvd) and master cylinder are under a year old and i havent seen any leaks as the clutch fluid reservoir is always full
Reply 0
Apr 20, 2018 | 06:27 AM
My clutch doesn’t slip, i just have the symptom where the clutch pedal goes like 1” off the floor after wot or if i rev it while pressing the clutch. (if i rev it in neutral, this doesn’t happen.) It returns to normal after a couple pumps. But then again, normal is like only 3” of play on the clutch pedal. Whereas every other car i’ve driven has like 4” of play.
I read somewhere here that it’s from a bad pressure plate, so i figure i might as well change both the clutch and flywheel since they both might be the originals
Reply 0
Apr 20, 2018 | 03:06 PM
Also, is there an oem rear main seal?
Reply 0
Apr 20, 2018 | 08:25 PM
YES, there is an OEM rear main crankshaft oil seal, NOT inexpensive, and only takes a few minutes to install, while the transmission is out.. Change it, weather it's leaking or not! Please verify with your local Acura Dealer, but, I believe the part number is: ( 11300-RCA-A00 ) Delray Acura OEM parts has it for $41.18, plus shipping. Amazon has it for $47.35, with free shipping. You may want to check with RockAuto, they should carry it as well, and may discount it because your buying the clutch there.
Reply 0
Apr 22, 2018 | 02:51 PM
Quote: YES, there is an OEM rear main crankshaft oil seal, NOT inexpensive, and only takes a few minutes to install, while the transmission is out.. Change it, weather it's leaking or not! Please verify with your local Acura Dealer, but, I believe the part number is: ( 11300-RCA-A00 ) Delray Acura OEM parts has it for $41.18, plus shipping. Amazon has it for $47.35, with free shipping. You may want to check with RockAuto, they should carry it as well, and may discount it because your buying the clutch there.
Thanks, I will change the rear main seal out as well. But on delray oem acura parts, the seal is $15.10 (91214-RKG-003). On rockauto it’s like $7, but they don’t have oem so I’ll get it from delray.
Reply 0
May 1, 2018 | 11:50 PM
OEM ONLY for that critical MAIN seal.
Reply 0
Subscribe
