Acceleration click noise Video
Old 10-01-2010, 03:57 PM
furnac3's Avatar
I recently bought my car at the Toyota Place from Garden Grove California, and my used car warranty is almost up in 2 weeks. I recently took my car to the service department about the click noise, and they said it was the loose brake pads that's causing this. The mechanics said that was normal cause the Corolla's has this problem too. I told them it was the axle nut that needs to be replaced or tighten, but he told me that it's not. Should I go back there to first this problem? Would it get worst later on in the future and my warranty is almost up and they dont cover it when it's expires.
http://www.youtube.com/watch?v=sZJYRN-5WSc
Old 10-15-2010, 09:36 PM
Chapter Leader (Central New Jersey)
07tl-s6spd's Avatar
thats the same click i have but from my driver side.....so is there any known definite fix for this yet????so they said it was brake pads huh...could be cause im do for some real soon...i dont have much pad left
Old 10-18-2010, 10:30 PM
07tl-s6spd's Avatar
anybody have a sure fix for this?????
Old 10-19-2010, 07:55 PM
The DVD-A Script Guy
Adobeman's Avatar
Here are a few posts about similar thing. My 05 6MT clicked for about a year and then stopped. Dealer tried the same "it's your brakes" line too.
These are short posts so give them a read
https://acurazine.com/forums/3g-tl-problems-fixes-114/07-tl-s-6-speed-manual-clicking-sound-when-starting-off-787997/
https://acurazine.com/forums/3g-tl-problems-fixes-114/07-tl-s-clicking-before-after-brake-use-785790/
Old 10-19-2010, 10:53 PM
07tl-s6spd's Avatar
thanx^^^im gonna change my pads cause i need it so while im at it ill buy new axle nuts and put them on too
Old 10-20-2010, 10:55 AM
01tl4tl's Avatar
Received 1,137 Likes on 1,067 Posts
has the lock mechanism on the axle nut been touched?
no reason for them to be removed -why do you think its loose?
put a torque wrench on it yet?
brake pad wear is possible--are there shims on your pad backs, thats to reduce noise--OE pads or aftermarket?
Old 10-20-2010, 04:11 PM
07tl-s6spd's Avatar
looks to me that the axle nut has never been touched.that lock part is pretty nicely pushed in there...i just figured i change it cause people have said this fixed there clicking..ill try to tighten it first and see if that helps.....the pads that i have are the original oem ones...i know there is barely any meat left....i need some like yesterday...lol
Old 11-09-2010, 03:15 PM
J35A8_Party's Avatar
AXLE NUT, AXLE NUT. Just have them replaced. they are 15$ a side.
I had this "exact" problem, went to dealer many times. I've posted this in another thread. My Axle nuts were "replaced" and I've never had this problem again.
buctl-s (12-08-2012)
Old 12-08-2012, 02:03 PM
buctl-s's Avatar
I just replaced my passenger side axle nut per this post. The noise is no longer there! I didn't replace my driver side axle nut yet as the noise is gone. Cheap fix for anyone that wants to try this.
Old 03-13-2015, 08:39 AM
tsmith1125's Avatar
Im having the exact same problem no one seems to know what it could be did anyone have this issue resolved and if so what was the ending result?
Old 09-29-2015, 11:10 AM
8th Gear
ModMechanic's Avatar
sure fix
I've been a career mechanic my whole life and the noise you're hearing is your brake pads sliding from front to back. Swaping for oem pads will not resolve the issue unless you also order new brake hardware (just the metal tabs that secure the pads in the bracket). This symptom will not cause any further damage. Its just a noise...
navtool.com
3G MDX (2014-2020)
32
01-20-2016 11:43 AM
navtool.com
31
11-16-2015 08:30 PM
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
joflewbyu2
10-08-2015 11:16 AM
navtool.com
09-25-2015 05:15 PM
Quick Reply: Acceleration click noise Video
