Abs Vsa Tc Lights on
Old Aug 12, 2025 | 10:23 AM
Zavikilla's Avatar
7th Gear
When I got this car I had intermittent problems with the abs tc triangle and vsa lights on. This would happen when the car sat in rain without being driven. after driving for about 30 minutes those lights would go away. I recently had the engine swapped and those lights have been on for 2 months now. The shop replaced the wheelspeed/abs sensor and cleared the codes but they just came right back. i heard this could be many things even the wheel bearings which Im fine with tackling myself but id like to confirm thats the problem. Im going to have the codes read today.
Old Aug 12, 2025 | 11:52 AM
EasyLoveRDX's Avatar
It's almost certainly one of your ABS wheel speed sensors.
Make sure to note which wheel, and also if it's the code for open/short to ground (11, 13, 15, 17) or intermittent noise/interruption (12, 14, 16, 18).
Old Aug 12, 2025 | 11:59 AM
Zavikilla's Avatar
7th Gear
The car was throwing a code for front passenger side abs sensor. replaced and still nothing. Ill get the codes read and probably replace all the sensors
Old Aug 12, 2025 | 06:03 PM
csmeance's Avatar
before throwing parts at the issue, test the wiring and make sure it's good and there's not a problem.
Old Aug 20, 2025 | 10:30 AM
Zavikilla's Avatar
7th Gear
Code read by acura states front left sensor error. I made a mistake, thats the one that was replaced earlier. If its not the sensor itself could this be a wheel bearing issue?
Old Aug 20, 2025 | 02:33 PM
What is the actual number of the code? "Error" isn't very specific.
Whether the code is for noise/interruption or open/short to ground is an important distinction for the diag process.
2002RL175kmiles
1G RL (1996-2004)
Dec 24, 2022 11:43 AM
Todd Gruchalski
4G TL Problems & Fixes
Nov 9, 2020 04:54 PM
tkgates
Aug 12, 2017 08:01 AM
bang47
Mar 13, 2010 03:04 PM
wilsel
Feb 26, 2006 02:43 PM
