6spd Gm syncromesh users I put the wrong m/t fluid!!! help...
Old Feb 19, 2014 | 01:23 PM
TL Luver's Avatar
2006 6spd
hey everyone I recently got an 06 6 speed that's like 40,000 miles and the second day I had it I change to the GM synchromesh fluid; the only problem is I didn't put the friction modified version how bad is that should I hurry up and go to replace it I've been running it for approximately 4,000 miles like that...I haven't noticed any problems car runs fine and smooth...thanks in advance for anyone's help...
Old Feb 19, 2014 | 01:33 PM
erdoc48's Avatar
06 Anthracite TL
Sorry to sound like a wiseass, but if it runs fine, why worry? If it does bother you that much, drain and refill.
Old Feb 19, 2014 | 01:37 PM
^I gave you the same advice, Jer.
if it gives you peace of mind, change it.
Old Feb 19, 2014 | 01:42 PM
ggesq's Avatar
jk.
Old Feb 19, 2014 | 02:15 PM
EvilVirus's Avatar
^ lol
OP come on bro you should know better
Old Feb 19, 2014 | 02:18 PM
ez12a's Avatar
the overexplainer
for the short term it wont really do anything. But for peace of mind i'd just get the FM stuff in when you're under the car again.
i'm not sure for the TL's particular transmission but in the hondas i've had you can run normal motor oil as a temporary replacement in a pinch. non-FM Synchromesh is probably better than regular motor oil.
Old Feb 19, 2014 | 02:38 PM
myron's Avatar
that GM one you put in there is better than a honda one anyway so relax. Change it if you want to friction modified, it's not gonna explode.
Old Feb 19, 2014 | 04:13 PM
ZOMGVTEK's Avatar
Personally I'd drive it for a few hundred miles and change it again irrespective of the fluid you use. Then again in another ~15K.
It really shouldn't bother the transmission one bit. It's not all that sensitive.
Old Feb 19, 2014 | 06:52 PM
TL Luver's Avatar
2006 6spd
Ok thank y'all; I kinda figured it would be at least better than stock..I remember correctly the FM stuff actually causes slippage and wear but makes smoother shifts so I was kind of thinking maybe the non FM would just be harder shifts and maybe last a little longer... but yes I'm going to change it next time I get a chance then instead of a immediatelymediately... thank you again everyone...
I guess well this state is open & I have the chance to ask; is there any synthetic manual transmission fluid people use with our car that has been proven to be ok?...would it be alright to maybe royal purple or something...I had Amsoil in my automatic...
cycdaniel
Dec 17, 2019 10:58 AM
tonio
Feb 5, 2019 05:43 PM
C2CuSn07 TL
Sep 11, 2015 06:54 PM
jfman55
Sep 5, 2015 02:55 PM
