6 spd...3rd gear grinding...TSB..can I demand a fix?
I have the third gear issue, and I'm aware of the TSB. Took it in when I got it at 49k, and they changed the m/t fluid, seemed to help a bit. Now it's doing it more.
The car is still under powertrain warranty.
Do I have the right to "bitch" or demand anything if they won't fix it?
They acknowledged it when I initially took it in, but didn't offer to fix it; they changed the fluid instead.
I don't want to fork over thousands in a few years time because of this.
As far as I'm concerned it has a faulty syncro(s), so yes they should do a replacement as long as it is covered by the powertrain warranty. Some recommend trying the GM fluid, but that is only a bandaide to cover up the problem. If it grinds or pops out of gear with the OE fluid, it should be fixed.
A lot of talk about the 5 AT problems, but the 6 MT's aren't much better as the syncros just don't last, and then there is the clutch assembly..........
Does make one wonder.
First...sorry to hear about the GRINDING...I have a 2007 Type-S 6MT...doing the same thing occasionally. I first noticed it shifting into 3rd... about a month ago.
You do have the opportunity to have the dealership repair that, considering their is a TSB on it. Second as you continue to grind it...those "shavings" are not helping ...even when they changed the fluid. Get it in to repair it...probably the syncros and replace the fluids again. I agree you do not have to "bitch" to get them to work on it. You can go far with the knowledge you acquire from these forums as I have! Ask the service writer what their next step will be, considering it will not be their first rodeo...they have seen this often. Good Luck!
When I brought my car in for the 6th gear grind, I had a copy of the TSB in hand, and 3 quarts of GM synchromesh in the trunk. They put me in a TSX loaner for a week, and replaced 3 pages worth of parts (synchros, the whole nine yards). If you are polite and seem knowledgeable, the whole process should go in your favor. Demanding or bitching will get you nowhere, and they will just give you Acuras CC number to wash their hands of the situation.
J
J
Lol, nah guys you got me all wrong. My bad. I didn't mean literally bitch and demand stuff, as I am on very, very good terms with the dealer. I just mean, can I respectfully say, "Umm no, you need to fix it (because of the TSB)," IF they don't seem receptive to doing it. They didn't really say "No, we won't fix it," rather, they were more like, "Let's change out the fluid and see how it does." Doesn't seem to be making a difference. Like I said, the dealer and I, we're tight. The service manager has done things for me that he didn't have to (like fixing a rattle and replacing a blown speaker AFTER the b2b warranty was out, giving me a new (free) battery when I didn't even know I needed one, etc.). So I am very impressed with the dealer so far. What I'm saying is, if they try to back out of doing thousands of dollars worth of work to my car that needs to be done, do I have the right to counter?
And I sort of disagree about the tranny issues, aside from the 3rd gear issue, it's rock solid. My clutch? Still will peel out (for a sec, not just "bark") in second if you pop it hard enough, and I've got almost 60k on it. I also love the way it snick snicks through the gears. Honda does manuals right.
At just over 75,000 miles with my '04 TL, I can also break traction in first second and third gears when getting on it hard. I expect a clutch to last longer than my ownership of the car and with every manual I have owned (which is all of my cars but one), that has been the case. I see the Acura clutch assembly as needlessly complex and frankly more prone to problems. I have not had any, but why introduce complexity where it is not needed? Once again, clutching systems are also not rocket science.
Not a rant against anyone... just simple observations.
Quick update...Today I had the car into the dealer to address the 3rd gear issue. While "Jason" the technician was trying to get 3rd gear to grind the service manager asked if i would like to have in inspected...considering they expire 2 months from now..."sure" I said. I mentioned that it is an intermittent issue and that there is a TSB on this problem...he said " OK, we will check it out". After the inspection was done and the service writer called me back...to show me they blew the trans!...(just kidding) NO, NO he showed me that they ordered the "3rd gear set up" for the specific TSB...about 3 pages! I drop it off next Friday. I will keep you posted. The dealerships will address and fix the issue at hand (They get paid to do the warranty work)
Cool. Hope it eliminates your problem.
FWIW, with a TSB you (the owner) can't really "demand" that the TSB be applied. You have to meet all the criteria of the TSB which often includes a limited VIN range and a series of trouble-shooting steps.
Also, if you're out of warranty they can deny the TSB. You can sometimes get "good will" coverage when you're out of warranty.
A TSB, essentially, is a an optional or limited fix. A Recall is NOT an optional fix (for the dealer/manufacturer) regardless of warranty expiration.
I do not want to burst the bubble, but I got mine 3rd gear syncro replaced several months ago and the problem is slowly coming back, so whatever the dealer did, it barely fixed the problem for 5-6 months.
Had my 3rd gear synchros replaced under TSB at 79,000 miles. Before the service 3rd gear was sticky, grindy, and would pop out, or refuse to engage. Now, I just hit 92,000 miles and 3rd gear has gone from the worst gear in the box, to the best. It's still smooth, firm, and engages like it's being pulled out of my hand like a magnet. Love those 3rd gear double clutch downshifts for overtaking!
Good for you. This is how you do it.
and you guys wonder why there are synchro issues!!!
Oh I love to double down and do max rpm downshifts- pretending to be a race car driver all the time in town--and I leave my foot on the clutch at lights so I am ready to blast off in a fury of smoke or traction~
A TSB is a `Technical Service Bulletin`- meant for acura techs and those who subscribe to major tech services acura sells info to- so they can fix odd problems
When someone discovers a prob and fix- they issue a TSB so other dealers dont waste time searching for problem- if it has these symptoms- ck this! simple system that works well for distributing repair information nation and worldwide
In the TSB- many have a clause saying if the fix doesnt work, or certain damage is found, then warranty will cover replacement of said part
TSB are not mandatory repairs or recalls- they are technician `cheat sheets`
Update on the TSB 08-018. I received my car back today after the Dealership had it since 5/28/2010. I have to commend the dealership here in PA, they replaced the third gear set and much more...shaft RE,sleeve,gear RE,bearing,washer...for 4th and 5th, and reverse. The car shifts smooth with no "grind", "popping" etc. Glad to have it back. The dealer had me in a 2010 TL Tech package 5spd AT...not a big fan. My sincere apologies to those who may own them.
As far as for TSB's I am well versed and aware of them...my father was a ASE Master-Tech for over 35years.
Hey. I saw a lot of posts regarding the third gear issue on 3rd generation TLs. I havea 2005 TL and there is always this grinding feeling whenever I shift into the third and even into fourth. There was a TSB issued in April 2008 on the same.
I called up the dealer and they said that its going to be 159 as diagnostic fee and the rest would depend on the costs. I know it’s been seven years for this car and there is no warranty but I just purchased this car couple of weeks back. I can use the GM Synchro FM fluid but that won’t fix the true problem. I am new to U.S. and would really appreciate some feedbacks on how I can best resolve the issue with the dealers.
a. Can I maybe convince them to help me out with some goodwill on the total cost. Is that even a possibility.
b. Should I go to a local trusted mechanic and get the 3rd gear synchronizer or 3-4 shift sleeve replaced.
c. Should I just continue on with it using the GM Synchro FM fluid and hope that the transmission doesn’t give up on me anytime soon. (if so the threads on the same are atleast a year old. Hence, any new suggestions on where I can get the fluid from. If not, I will just use the link from older posts.
Any suggestions from someone who faced similar problem out of warranty would be great.
Before embarking on the TSB, buy three quarts of ACDelco Synchromesh Friction Modified and use it to replace the MTF in your transmission. The odds are pretty high the new MTF will cure your transmissions ills (just like it fixed the third gear grind/pop out issue on my car).
- Here's the stuff you want in your transmission: https://smile.amazon.com/ACDelco-10-...8FK/ref=sr_1_2
6spdtls
Feb 14, 2008 01:39 AM
