3G TL Failing Window / Weather Stripping Fix
Old 10-15-2013, 10:40 AM
rockstar143's Avatar
Received 19,916 Likes on 14,458 Posts
Not rocket science but figured I'd share my own little fix since I'm sure that as time goes on MOST of us will encounter this issue as the rubber's been baking in the FL sun for 10 years now.
It happened to my rear window outer "moleskin" type of weatherstripping...it corroded at the bottom and the fist 6 inches were flapping in the wind. Note that I am pretty good about a yearly application of shin etsu, but this one was too far gone. I'm sure I could just replace the rubber, but this will work for now. My first fix was to put a piece of gorilla tape in there and that held up for a year or 2 but the sun eventually cooked the adhesive backing on it.
Yesterday I ran a dab of black adhesive silicone rtv along it and then used some plastic shims fro when I installed my laminate flooring to hold in place while it dried. I'm sure this will hold up for quite a lot longer than the tape!
Hope it helps someone out,
J.
Old 10-15-2013, 11:45 AM
EvilVirus's Avatar
Received 1,120 Likes on 893 Posts
Good job there rockstar
rockstar143 (10-16-2013)
Old 10-16-2013, 02:21 AM
paperboy42190's Avatar
Received 1,162 Likes on 847 Posts
the oem pieces are ridiculously expensive for what it is....otherwise most ppl would just buy new ones.
nice work jeremy
Old 10-16-2013, 07:18 AM
Thanks, boys.
Honestly, I would PROBABLY buy it but it feels like a waste since the majority of the rubber is just fine. Also, I changed out that piece that holds the rear quarter glass in place...it was a pretty penny, a PITA to change out and guess what...the replacement one is now getting those weird ridges on it too!
udelslayer
1G RDX Problems & Fixes
05-06-2016 12:27 PM
BoricuaTL
04-08-2016 01:08 PM
ahsm
09-09-2015 08:35 AM
gqdabien
09-08-2015 11:41 PM
Quick Reply: 3G TL Failing Window / Weather Stripping Fix
