3G TL engine mounts -- reasonable cost for replacement?
Hey, guys.
I'm trying to get a sense of how much it might cost to replace the rear/back engine mount on my 2007 TL including parts and labor.
Had my front and side mount replace about 11 months ago and figured I'd get the rear/back one replaced now. My guess is that my mechanic didn't do all 3 at once because it might be prohibitively expensive.
So, what do you think a reasonable price (again, part and labor) would be to replace a rear/back engine mount for the J32A3?
TIA
TIA
Hey, guys.
TIA
TIA
Are you still having symptoms or you just want to get it replaced? I’ve been having pretty bad symptoms for the past year or so and when I had my mechanic look at it he said the front and side ones were damaged. Didn’t do anything about the rear so I didn’t ask. I was assuming the rear one was fine or just not worth it to replace at this point.
But your approach sound logical. So, I'll probably just let it go, like you have.
Thanks again!
bdtl
Jun 12, 2016 07:52 PM
