3 x 3 fluid flush
Old Mar 1, 2016 | 11:30 PM
bigmutt's Avatar
3 x 3 fluid flush
sorry ... but what is a 3 X 3 ??
did some searches but nothing came up
thanks
Old Mar 1, 2016 | 11:55 PM
csmeance's Avatar
change the transmission fluid 3 times with 3 quarts of new fluid each time. Trans holds 9 quarts of fluid and you can only replace 3 at one time.
Old Mar 2, 2016 | 12:47 AM
CenturionTL's Avatar
https://acurazine.com/forums/third-g...stions-921273/
http://www.tegger.com/hondafaq/p0420/B080100.pdf
Old Mar 2, 2016 | 07:25 AM
Adobeman's Avatar
The DVD-A Script Guy
Also - It's an auto transmission thing only. I say that because I do remember some confusion in the past.
Old Mar 2, 2016 | 07:36 AM
JasonK's Avatar
09 TL SH AWD /w TECH
Of course it's a auto transmission only. Torque converter is what holds most of the fluid while the actual tranny holds 3 - 3 1/2L.
Proper way to do the three by three flush is get the car hot and then flush the fluid. Measure what comes out and put the same amount back in. You'll never get all of the old fluid out so its best to do another flush on the next or second oil change after the 3 by 3 flush. Then after doing the first flush go road test and go through the gears and do the flush again with the tranny fluid hot and measure again what comes out.
Rinse and repeat its pretty easy. You can even do it yourself if you can access the drain plug with a 3/8s ratchet. It's by the middle of the car where the black cover is covering the tranny. Fluid will drip on there and you will have to clean it up with brake clean and a rag.
Djunknown12
Aug 12, 2016 05:31 PM
ericcdong
Mar 18, 2016 07:11 PM
Hammer Time
Feb 27, 2016 05:12 PM
FRobledo05TL
Feb 13, 2016 06:15 AM
Mcj270
5G TLX Problems & Fixes
Jan 19, 2016 08:05 AM
