200xxx mark
oil leaks from valve covers, spark plug tube seals, oil filter housing, rear main seal, cam inspection plugs, etc.
Fluids, filters and the usual stuff
Make sure you do valve adjustment when you do timing belt and use an AISIN kit; don't buy from amazon/ebay. Rockauto is the best source for genuine parts.
uhh, everything.
assuming nothing has been changed since 200,000 miles ago...
remember, a car is a machine. machines have moving parts. moving parts fail.
rubber deteriorates, plastics become brittle, bearings seize.
If you are waiting for hand holding, you most likely won't get it. There are lots and lots and lots of threads from the past 15 years that discuss basic maintenance tasks in quite a bit of detail. I would suggest doing some more searching and reading on here and other sites, decide which ones you want to tackle first, then go from there.
Beaverking
6G TLX (2021+)
251
Feb 1, 2021 08:07 AM
