2008 TL type S Shifting hard
Old Jan 15, 2019 | 08:13 AM
NoClu's Avatar
i have been looking through the threads for possibly one on hard shifting. Haven’t seen one unless I over looked it.
Ifbthis is posted somewhere someone please redirect me.
i have a 08 type s w/at. It was shifting hard from 2 down to 1 and sometimes from 2 to 3. I changed the fluid out and it’s still doing it. Possible shift control sylinoid, what’s there 3x3 cleans or changes I have heard of, pressure switches...
any help is appreciated thanks!!
Old Jan 15, 2019 | 08:26 AM
horseshoez's Avatar
Latent car nut
The 3rd and 4th gear pressure switched are certainly worth replacing; what kind of ATF did you put in your car and how many miles was on the ATF you drained out?
Old Jan 15, 2019 | 08:52 AM
NoClu's Avatar
76000 when I drained it and use Honda fluid from the dealer
Old Jan 15, 2019 | 09:06 AM
BreezyTL's Avatar
Next I would do switches.
Old Jan 15, 2019 | 09:13 AM
horseshoez's Avatar
Latent car nut
So 76,000 miles on the factory fluid? I strongly recommend both the switches and a 3x3 fluid change (of which you've already done the first) with Honda DW-1.
Old Jan 15, 2019 | 09:37 AM
NoClu's Avatar
which switches?
Old Jan 15, 2019 | 09:39 AM
NoClu's Avatar
what shouldnthe mileage be between the 3x3 changes? Also that means just draining and filling the fluid right... and which switches exactly? Any posts on where they are located and how to possibly? I can do most of car stuff on my own but find how tos with pics or video is the hard part at times
Old Jan 15, 2019 | 09:46 AM
which switches?
the 3rd and 4th gear pressure switches/solenoids..
Old Jan 15, 2019 | 09:47 AM
Pressure switches or Solenoids... same thing.
remove driver side wheel. all the solenoids will be on the tranny case in that drivers wheel well.
because Automatic transmissions have clutch packs, NOT ALL tranny fluid will come out when you remove the drain plug.... so, you cycle new fluid with old fluid, BY DRIVING. enough driving to cycle the fluid.
basically, you're mixing old with new, until you have all new fluid... hence the 3x3x3 method....
drain 3 quarts...cuz only 3 quarts will come out.
Fill 3 quarts..... Drive.
do this 2 more times...
3x3x3 method.
Old Jan 15, 2019 | 09:50 AM
NoClu's Avatar
the hard shifting is going down to first from second and at time from second to third. So just the third to fourth would fix that?
Old Jan 15, 2019 | 09:57 AM
NoClu's Avatar
3x3x3 method.
are the switch attached to the control solenoid?
Old Jan 15, 2019 | 09:58 AM
well, you still have old shitty fluid in there....as horseshoez mentioned.....do the fluid swap 2 more times
Old Jan 15, 2019 | 09:59 AM
not a conventional on and off switch.... it's a solenoid. pressure switches is just another name for them...
they have wires and a molex connector attached to a solenoid screwed into the tranny case.
remove drivers side wheel.
look at tranny case through drivers side wheel. you will see wires going to a plug that screws into the tranny case... remove the molex connector, then unscrew the actual solenoid.
Old Jan 15, 2019 | 10:03 AM
NoClu's Avatar
Ok
Old Jan 15, 2019 | 10:04 AM
NoClu's Avatar
ok hopefully it fixes it.. thanks for all the help!!
Old Jan 15, 2019 | 10:08 AM
Google "3rd and 4th gear pressure switches" and you will find the location and what they look liek
Old Jan 15, 2019 | 11:46 AM
NoClu's Avatar
Is there a second gear switch? That’s the one with the biggest issue
Old Jan 15, 2019 | 11:49 AM
What fluid did you use?
Old Jan 15, 2019 | 11:57 AM
NoClu's Avatar
dw-1
Old Jan 15, 2019 | 12:00 PM
the type-s has more pressure switches that need to be changed than the base.
Google it.
"Acura TL pressure switches" "type-s pressure switch location"
Old Jan 16, 2019 | 06:18 AM
Slpr04UA6's Avatar
-------Tim-------
Link below to pressure switches for 2007-2008.....
https://acurazine.com/forums/third-g...2008-a-840630/
Old Jan 25, 2019 | 07:38 AM
NoClu's Avatar
So I had a friend hook his reader into my car to see which solenoid was bad and it pulls up pressure switch B. Nothing I have read mentions switch a, b or c. Are they the 2,3 and 4 pressure switches?
Old Jan 25, 2019 | 12:22 PM
Replace switches.
Old Jan 28, 2019 | 07:17 PM
NoClu's Avatar
So I just changed the solenoids and in and out of third is still a little rough. An idea where I should go from here...
Old Jan 29, 2019 | 08:55 PM
Which solenoids? You were supposed to change pressure switches..
Old Jan 29, 2019 | 09:04 PM
NoClu's Avatar
I did all three pressure switches.
Old Jan 29, 2019 | 09:09 PM
horseshoez's Avatar
Latent car nut
All three?
Old Jan 29, 2019 | 09:20 PM
NoClu's Avatar
One on the front one under motor mount and one on back by intake
Old Jan 30, 2019 | 07:07 PM
OEM switches?
Old Jan 31, 2019 | 04:29 AM
NoClu's Avatar
Yep
Viewfinder88
Nov 25, 2019 11:31 PM
thelastaspec
Jan 2, 2016 06:05 AM
vilcafor
Aug 27, 2010 03:06 PM
Localmotion
Feb 20, 2010 10:08 PM
thholr
Jun 16, 2001 05:18 AM
