2008 Acura TL
The front end collision might have had something to do with it..
Maybe the cluster itself ?
Is the ECM still in the car? Does it run?
Can you put a battery on it and turn the ignition to the ACC spot and maybe it'll reset itself?
The cluster itself works off a serial communications network that runs through the car. There's actually a test to check the cluster range that can be entered, there's a thread on how to enter the mode somewhere here.
My guess is it lost power at about 50mph when it was in the front end collision and the cluster probably froze there.
Im trying to fix the car, When i have the key in i can get the hazards lights to work and the brake lights to work aside from that everything else is dead, the accident mainly was on the front passenger side, as for the fuse box it looks alright no damge or anything to it.
HeloDown
09-08-2015 06:51 PM
darksky
09-05-2015 03:11 AM
