2006 TL with P0741
Old Jan 28, 2020 | 06:07 PM
indcoltsfan32's Avatar
4th Gear
2006 TL with P0741
Hello all,
I have a 2006 TL with approx 150K on it. All of the sudden while driving, the transmission started slipping pretty bad (has never showed a single sign of a transmission issue at all). Have done trans services ever 30k (3x3x3). No check engine light/no lights on in dash. When I stop, put it in park and back into drive it still slips. However, when I stop, put it in park, shut it off and restart it right away it will drive perfect for approx 1/4 mile then start slipping again. Eventhough there are no lights on, I checked for codes p0741, which I guess is the death code for transmissions.
Being that it has never showed any signs of an issue, and it drives fine after shutting it off for a second. I hope to think the transmission isint toast. What are some things I can check to make sure?
Also, if it does end up needing a transmission. Are there any transmissions (auto) that will swap over? Im thinking Accord V6 transmission, but is it a direct fit or do I need to transfer anything to make it work properly?
Daniel Chassin
Sep 24, 2019 10:47 PM
Busterdog1
May 22, 2019 07:25 PM
MadeYouReadThis
Aug 2, 2017 01:37 PM
Angelo1
Jul 18, 2017 11:08 AM
Angelo1
Apr 24, 2017 08:00 AM
