Are all 2006 Acura TL 3.2 automatic transmission interchangeable
Hi everyone I purchased a 2006 Acura TL with 223,000 miles I did a 3x1 transmission fluid change now the transmission won’t go in any gear I located a 2006 tl in the salvage yard that was smashed in the front it has 158,000 miles on the windshield and the engine and transmission appears to be in good shape checked the transmission oil and it looks really good my tl is a automatic with a slapstick and the tl in the salvage yard is a automatic without the slapstick can someone tell me if this engine and transmission is interchangeable with mines thanks the salvage yard sells the engine for $300 and the transmission for $170 thanks
all trans for 2006 is the same! I would suggest you get the used one checked out before you put it in.
Latent car nut
Received 2,005 Likes
Now, on to the transmission itself, why screw around with another soon to fail 2006 transmission; if you're going to put in a used/unremanufactured transmission, go directly to a Honda Accord 2006-2007 V6 transmission (with the build code of BAYA).
slimmyjimmy
04-12-2023 05:01 PM
SoulPersona
1G RDX Problems & Fixes
08-31-2017 01:06 PM
StressFreeCarpentry
1G RL (1996-2004)
07-01-2012 01:25 PM
