2006 TL auto trans problem!
Old Nov 13, 2016 | 04:15 PM
Brad.weber1990's Avatar
8th Gear
Whats up guys!? Been searching forums and cant find anyone with the same symptoms my TL is giving me. 06 tl with auto trans that has 195k miles on it. When driving the car it pops into what feels like neutral after moving only when the car gets hot. The motor revs up but the car wont continue to move. Seems to be all gears. I tried flushing the fluid multiple times and it continues to come back it'll be fine for a few days after flushing but then it comes back. Dont want to just throw a trans in it if its something dumb and easy to fix.
Thanks!
Old Nov 13, 2016 | 04:18 PM
Needs a new trans
Old Nov 13, 2016 | 04:27 PM
8th Gear
Forgot to add if i shut the car off and let it cool for 1-2 minutes its fine for awhile again!
Old Nov 13, 2016 | 05:53 PM
AZuser's Avatar
_
Looks like trans is toast.
Old Nov 14, 2016 | 10:11 AM
flyromeo3's Avatar
trans is shot.
Torque converter has overheated and scorched the clutches and steals.
rebuilt or replace is the only thing left to do.
Old Nov 21, 2016 | 04:41 PM
8th Gear
Car now has a permanent triangle with an exclamation point in the middle of it. Un hooked the battery and everything and it wont go away. The car now will not move at all. My buddy has a snap on verus and we are not getting a single code at all. Im wondering if its an electrical or selonoid issue??? The problem is no codes and cant find anywhere with the same symptoms.... HELP! Thanks guys!
Old Nov 21, 2016 | 06:51 PM
Are your axles broken by chance..?
Old Nov 21, 2016 | 07:22 PM
8th Gear
Nope when you put the car in park it holds
Old Nov 21, 2016 | 08:05 PM
MarcDavidoff's Avatar
What does the fluid look like? Sounds like others have mentioned that the trans is done. Passages are probably clogged. When you let it cool down it may help a bit but that's it. AV6 swap would be the route to go
Old Nov 21, 2016 | 08:44 PM
8th Gear
so i can do the av6 swap in a 2006 tl? What year and model accord trans is it???
Old Nov 21, 2016 | 08:53 PM
Yes from what I understand it can be done for 04-06 as well. Someone else may chime in with details..
You can look for an 06/07 V6 non hybrid accord trans. I'd start at car-part.com. A good price for one with under 100k miles would be around $1k plus or minus.. Seems kind of odd you aren't seeing any codes though.
Here is the main AV6 swap thread https://acurazine.com/forums/second-...n-swap-905115/
Old Nov 22, 2016 | 07:15 AM
8th Gear
I cant find anything for swapping the av6 into a 3g TL only thing I saw was for up to 2003 I believe?
Old Nov 22, 2016 | 11:37 AM
It can be done on 04-06 as well. I am pretty sure there is a thread or two from guys who have done it
Old Nov 30, 2016 | 01:57 AM
Majofo's Avatar
are you sure it revs and it's a no go?
If the dash lit up like christmas tree and it wouldn't rev past 3k RPM (limp mode), it would be your app sensor (it would throw code P21xx something)
but if it's revving and no go.. as thoiboi said, not the axles, it's your trans..
I find it a little strange that it'll be fine for a few days after fluid change though..
That usually exacerbates the issue, assuming it was on old fluid to begin with.
EE4Life
Mar 12, 2020 07:29 PM
IWishIHadA_NSX
New Member Introductions
Nov 9, 2016 11:08 PM
jamestheunderdog
Oct 23, 2016 06:38 PM
Duronn
May 24, 2016 10:00 PM
EE4Life
May 14, 2016 07:14 AM
