2006 Acura TL Battery light randomly coming on
My battery light has recently started to come on randomly and drains the charge in my battery. The alternator passed the test at AutoZone and I took it to a generator/alternator shop. He replaced the regulator in it and said everything else was fine in it as he has done some work on it before. When the regulator in the alternator was replaced, my battery light did not come on for a good two whole days. When the light usually comes on its with 30 seconds to 5 minutes of me starting my car whether I'm driving or just sitting idle, it doesn't matter. Some times I'll have days when the light doesn't come on at all. What I've been doing is getting my battery charged (is this bad for the battery? Will it shorten its lifespan if I get recharged a lot?) at either AutoZone or Walmart until I figure out the problem.
190,000 miles on the car
Battery is brand new, only a month old.
Serpentine belt doesn't look worn out nor does it make a noise indicating that it is slipping. (Can serpentine belts even slip?)
No noticeable cables that look damaged from what I can tell
But from what I'm guessing it must be an electrical problem since it varies as to when the battery light comes on. But when I drive it usually does come on more than it doesn't. Does anyone have any insight as to what the problem may be? Has anyone encountered something like this? Any help is much appreciated.
Registered Bunny
I would still test the battery with a multimeter.
Could be your battery cables. They rarely look damaged because of the insulation around them but it happens sometimes that they're broken inside. It could also be your ring connectors being loose on the battery.
Registered but harmless
Received 1,149 Likes
First, check the cable clamps on the battery side for tightness and corrosion-- the negative clamp is borderline oversize for the post and sometimes gets loose.
Then check the negative ground and alternator connection.
Also check the positive cable for a couple of feet behind the battery clamp-- feel for corrosion.
A defective HFL (stays on for more than 30 minutes after the car has been turned off) has been known to drain batteries, but the battery light doesn't activate unless the battery is bad.
G/L, and welcome to AZ.
I got the new battery after the light started coming on so I know it's not that. I'll check the cables, but how would damaged cables turn the battery light on? I thought the light meant that my car is running on ony the battery which means that it has to be something that works with the alternator right?
If not, then the alternator needs to be tested and its connections checked.
My battery light started doing the same thing yesterday. It will stay on when I first start my car but turns off after about a minute of driving and seems to go away once I have picked up speed. The light turns back on after I come to a stop for a extended period of time (doesn't come on at a stop sign or stop light). I'm going to drop by autozone on my way home from work this afternoon, i'm worried it's the alternator. I purchased my battery 6-8 months ago so there's no way its already going out. Plus, the previous owner disconnected the bluetooth because he said it was draining the battery so my bluetooth is turned off.
to check and see if the battery or alternator doing as following.
1. Start the car up and let it run.
2. disconnect one of the battery terminal.
3. DO NOT rev your engine while the car running WITH disconnected battery, this can damage other electronic in your car due to overload in spike voltage.
4. If the car shut off it's your alternator gone bad, if the car does not stop and continue to run for 15 mins then it's your battery.
Turned out to be my alternator after all. I guess it was just in a dying stage or something. The light started coming on all the time so I took it to an auto store and had it tested while in the car and it was the alt. Went ahead and bought a new one and now everything is good. Had to get a 2nd alternator though because the first one I received was faulty.
handsom-hustla
11-13-2015 05:04 PM
