2004 Acura TL help
Old Oct 17, 2015 | 04:39 PM
Mainplay's Avatar
4th Gear
2004 Acura TL help
I was just driving my car was fine, I stopped at a stop sign. Tried to accelerate the car went really slow, looked down the vsa light and engine light were on. I turned the car off and on and it worked. Just check engine light still on. Transmission on its way out?
Old Oct 17, 2015 | 08:14 PM
csmeance's Avatar
it could be a variety of problems. Autozone will read the code for free, Post it here
Old Oct 17, 2015 | 08:16 PM
Will Y.'s Avatar
Registered but harmless
Can't tell-- you need to get the error codes off with a code reader and then post them here.
If your engine RPM didn't increase with the accelerator, it's more likely the APP (Accelerator Pedal Position) sensor, but the error code(s) will most likely tell you the cause.
Old Oct 18, 2015 | 04:00 PM
polish_pat's Avatar
A 10$ OBDII bluetooth adapter (many under 10$ on ebay) + a 5$ Android app called Torque should be in every car owner's toolbox. Saves a lot of headaches just to know what that code means instantly.
Doc.Hollow
Jul 5, 2020 01:38 AM
vectorracer
Aug 5, 2018 05:38 AM
pstomps
1G CL Problems & Fixes
Oct 26, 2015 03:31 PM
A4orce84
Oct 20, 2015 06:18 PM
jbc3
Oct 17, 2015 12:55 AM
