2004 Acura TL help
2004 Acura TL help
I was just driving my car was fine, I stopped at a stop sign. Tried to accelerate the car went really slow, looked down the vsa light and engine light were on. I turned the car off and on and it worked. Just check engine light still on. Transmission on its way out?
it could be a variety of problems. Autozone will read the code for free, Post it here
Registered but harmless
Received 1,149 Likes
If your engine RPM didn't increase with the accelerator, it's more likely the APP (Accelerator Pedal Position) sensor, but the error code(s) will most likely tell you the cause.
A 10$ OBDII bluetooth adapter (many under 10$ on ebay) + a 5$ Android app called Torque should be in every car owner's toolbox. Saves a lot of headaches just to know what that code means instantly.
01acls (10-18-2015)
