2004 Acura TL failed inspection for engine light
Old Jun 19, 2012 | 09:00 AM
xdaily's Avatar
The codes on the report are P0134 and P2251. Does anyone know exactly which sensor this is and where it is located on my car?
Old Jun 19, 2012 | 11:23 AM
alexb92's Avatar
The first code comes from the Bank 1 oxygen sensor - somewhere along the exhaust, I believe the first one downstream (not 100% sure), and I believe the second code is related to the same sensor.
Old Jun 19, 2012 | 12:01 PM
xdaily's Avatar
Thank you! Can anyone help/confirm?
Old Jun 19, 2012 | 12:14 PM
imakeholesinu's Avatar
A quick google search and search of the forums returned these two threads which confirm this:
https://acurazine.com/forums/3g-tl-2004-2008-93/how-do-i-replace-front-oxygen-sensors-o2-808497/
https://acurazine.com/forums/3g-tl-problems-fixes-114/e-130-diy-oxygen-o2-sensor-installation-rear-upstream-f-aka-p2251-811823/
Old Jun 19, 2012 | 02:31 PM
xdaily's Avatar
word.
Old Jun 19, 2012 | 06:05 PM
newkatbie's Avatar
Bank 1 O2 sensor needs replacement.
Old Jun 20, 2012 | 07:34 AM
xdaily's Avatar
Thanks guess Ill be buying one and trying to do it myself.
Old Jun 20, 2012 | 07:48 AM
xdaily's Avatar
So Bank 1, Sensor 2?
2004 Acura TL failed inspection for engine light-2009-01-13_023953_jap_car.png
Old Jun 20, 2012 | 08:50 PM
vietxquangstah's Avatar
P0134 = Bank 1, Sensor 1 02 Sensor Circuit No Activity Detected
Your second code for P2251 also has to do with Bank 1, sensor 1.
Could be as simple as replacing it with a new sensor for ~$100-$150.
Good luck and come back with results!
Old Jun 21, 2012 | 07:13 AM
xdaily's Avatar
So it seems everyone agrees on the Bank 1 part ,but the sensor (1 or 2) seems to be in question.
Old Jun 21, 2012 | 04:46 PM
Turbonut's Avatar
P0134-Rear Air Fuel ratio Sensor, Bank 1, Sensor 1, heater system malfunction
P2251-Rear Air Fuel ratio Sensor, Bank 1, Sensor 1, VS circuit high voltage
Old Jun 21, 2012 | 08:58 PM
You must not have read what I posted
Old Jun 22, 2012 | 07:15 AM
xdaily's Avatar
Thanks guys. I just wanted really solid confirmation and now I have it. I appreciate your patience
Old Jun 28, 2012 | 11:51 AM
xdaily's Avatar
Rented the o2 sensor socket from autozone and change it out. Pulled a battery terminal to reset the codes and ALL GOOD!! Thanks guys.
Feb 25, 2020 09:57 AM
orkoTL
4G TL Problems & Fixes
107
Sep 28, 2017 09:12 AM
wusty23jd
Sep 24, 2015 11:41 AM
Bahamanurse1
Sep 10, 2015 10:05 PM
ptbarnett
3G RLX (2013+)
Aug 30, 2015 12:39 PM
