07 type s tranny problems
I have a 07 tl type s and when I put it in nearby doesn’t drive the car been sitting for a while and has code p0983 previously I it had p0974 and I changed the solenoid I seen that I may have broke the harness wire and would have to change that to fix the code should it be fine after if not would adding transmission fluid help and some Lucas or is the transmission done
What I meant to say is “I have a 07 tl type s and when I put it in gear it doesn’t drive. the car been sitting for a while and has code p0983 previously I it had p0974 and I changed the solenoid causing p0974 and the code cleared .I seen that I may have broke the harness wire causing p0983 and would have to change that to fix the code should it be fine after if not would adding transmission fluid help and some Lucas or is the transmission done[/QUOTE]
Gonna replace the whole mechanism probably just gonna sneak one out of the junkyard
I had to replace the connector already because it was blown
i fixed the wires then code p1717 popped up. I cleared it and it went away
teng
Aug 8, 2007 10:19 PM
