07 type s tranny problems
Old Mar 27, 2025 | 07:42 PM
Jahh's Avatar
I have a 07 tl type s and when I put it in nearby doesn’t drive the car been sitting for a while and has code p0983 previously I it had p0974 and I changed the solenoid I seen that I may have broke the harness wire and would have to change that to fix the code should it be fine after if not would adding transmission fluid help and some Lucas or is the transmission done
Old Mar 27, 2025 | 08:00 PM
Care to repost in English?
Old Mar 27, 2025 | 08:31 PM
Originally Posted by Jahh
has code p0983
Old Apr 6, 2025 | 06:40 PM
Jahh's Avatar
What I meant to say is “I have a 07 tl type s and when I put it in gear it doesn’t drive. the car been sitting for a while and has code p0983 previously I it had p0974 and I changed the solenoid causing p0974 and the code cleared .I seen that I may have broke the harness wire causing p0983 and would have to change that to fix the code should it be fine after if not would adding transmission fluid help and some Lucas or is the transmission done[/QUOTE]
Old Apr 6, 2025 | 06:46 PM
csmeance's Avatar
dont put lucas in yet, fix the wires that are causing the codes.
Old Apr 6, 2025 | 06:52 PM
Jahh's Avatar
Gonna replace the whole mechanism probably just gonna sneak one out of the junkyard
I had to replace the connector already because it was blown
i fixed the wires then code p1717 popped up. I cleared it and it went away
RyZEN
22
Jun 5, 2017 08:48 AM
JetLife2324
Jan 7, 2016 03:35 PM
teng
Aug 8, 2007 10:19 PM
