07 Av6 D5 Blinking
Old Nov 21, 2015 | 03:59 PM
JetLife2324's Avatar
6th Gear
07 Av6 D5 Blinking
Did the 07 Av6 over the Summer time of this year everything thing went very smooth with the swap no issues until today. My D5 light started blinking but no CEL or TCS like our previous tranny fails. The 07 Av6 still shifts outstanding prior to the swap the only things I didn't change were the pressure switches from our tl was this needed? Thinking this might be the issue but not sure? In Need of help thanks in advance
Old Dec 12, 2015 | 01:37 AM
01acls's Avatar
When the D5 blinks but no code means only the dealer can read those code(s).
Old Dec 16, 2015 | 02:11 PM
ErickUa5's Avatar
Mr.Helpful Diagram
Eventually its going to light up the CEL and TCS, Not sure that the dealer would check that for free. Unless you know someone with a scan tool capable of reading the AT codes.
Old Dec 16, 2015 | 02:27 PM
Chojun's Avatar
That's my experience as well - the dealers like to charge for a full hour of work at a minimum even if it's a 5min job. Unless you have a good relationship with them that is but if you have a 13+ year old car they aren't going to care much about your business.
Old Dec 16, 2015 | 03:20 PM
ErickUa5's Avatar
Mr.Helpful Diagram
Maybe the paper clip method would help in this case.
Old Jan 7, 2016 | 03:35 PM
SuperGreg's Avatar
You can always read the codes for all systems (PCM, ABS, TCS/VSA, SRS) by jumping pins 4 & 9 on the OBD2 connector and turning ignition to ON. Count the blinks on each indicator light. Major code has slower blinks (rapid blinks in a row means 10) followed by minor code with slightly faster blinks. Or, something like that
roman1998
Nov 7, 2015 11:32 PM
Topher Mueller
1/2G MDX (2001-2013)
Nov 4, 2015 07:19 PM
Typer0817
Nov 3, 2015 09:29 PM
cipdagr3at
Oct 29, 2015 12:37 PM
Thecrazytrains
1G TSX Problems & Fixes
Oct 28, 2015 09:46 AM
