'07 TL Type S Rev limiter issue
Old Jun 3, 2012 | 09:48 AM
gtstang03's Avatar
Hey guys.
Kinda new to the forum.
The TL i s my daily driver.
It is a 2007 TL Type s Auto with 90,000 on it now.
I got it at 75,000 and was told the trans has been serviced once. I know it is due again.
The issue is if you go WOT in 1st, about 5500 RPM it will feel like it hits the rev limiter for a few seconds and then it will skip past and keep going to the normal rev limiter. It does it every time.
Not even sure if it is the rev limiter, but it for sure feel like it.
It won't do it in any other gear.
It will do it with both VSA on or off and in manual or auto mode.
Anybody have anyideas.
Old Jun 3, 2012 | 11:03 AM
Bearcat94's Avatar
AZ Community Team
That is near the VTEC engagement point (4900?? - Justinspace, where are you?).
I'd check the VTEC solenoid and oil pressure (or whatever) to make sure the car is engaging the VTEC cam lobes properly.
Old Jun 3, 2012 | 11:14 AM
gtstang03's Avatar
Never though of that. i will look into this.
Old Jun 3, 2012 | 01:06 PM
paperboy42190's Avatar
4950. we dont need justnspace lol jk
Old Jan 19, 2014 | 07:53 PM
SNACKMAN's Avatar
Hi, I am wondering if anyone figured out what the issue is, I have a 2007 RL ASPEC and recently started experiencing the same issue, if I floor the pedal, it will seem like it's hitting a rev limit at 5500 to 6000 rpm, and then after a couple secs goes past it to the actual rev limit. This only occurs in 1st gear, all other gears will hit actual rev limit. This is super annoying, please help me.
Old Jan 19, 2014 | 09:36 PM
GRAF-FITI's Avatar
low vtech fluids
Old Jan 19, 2014 | 09:47 PM
DynamicJ32's Avatar
^ lol.
Yes, typically it is just low on oil.
Old Jan 20, 2014 | 07:27 AM
SNACKMAN's Avatar
could be, I'm due for an oil change, will top up and try as well as get oil change this week.
Old Jan 20, 2014 | 07:20 PM
ZOMGVTEK's Avatar
Where does it read on the dipstick?
I would think you'd have to be quite low for this to happen.
Old Jan 23, 2014 | 05:54 PM
SNACKMAN's Avatar
You are correct my friend, Dip Stick was veryyyy low, I had to add 1.8 quarts to get it upto the right level. All is well now. Thank you.
Old Jan 23, 2014 | 07:34 PM
I hate cars's Avatar
Sorry but that's BS. If the oil level was low enough to cause vtec to not engage you would have engine damage. While it's not ideal, 1.8 quarts low is not enough. You will experience the problem again.
Old Jan 23, 2014 | 09:24 PM
SNACKMAN's Avatar
Hmm... Well VTEC was engaging in all other gears...... it engaged in first as well, but not quite through the entire power band. After topping it up, I have opened up the throttle many times, no issues. VTEC in every Gear including 1st with zero issues. Mind you, I haven't had a chance to try vtec in 5th yet, but 1,2,3,4 are a go
Old Oct 26, 2016 | 03:25 PM
Hatfield1013's Avatar
Bump...
I am having this same issue in my 2007 TL-S with 124k. If I punch it in 1st, at 5500rpm the rpms briefly encounter a limiter similar to redline, then keep climbing to 7k. The car has started to do the same in 2nd gear on occasion. The odd thing is I put the car in sport shift mode and accelerated slowly in 1st all the way to 7000 rpm without this occurring. I will try to take a video tonight.
My oil is at the full level on the dipstick, so I don't think that is the issue. A 2x3 with Redline D4 was done about 10k ago, and the trans shifts fine while accelerating normally. No CELs to speak of. Alternator recently was replaced though.
Old Oct 26, 2016 | 03:40 PM
Just an odd top off the dome idea, maybe the APP sensor is on its way out??
Old Oct 26, 2016 | 03:41 PM
https://acurazine.com/forums/3g-tl-p...sensor-730958/
Old Oct 26, 2016 | 03:42 PM
Or perhaps the VTEC solenoid???
Old Oct 26, 2016 | 04:30 PM
truonghthe's Avatar
several things could goes wrong here.
1. Check APP sensor
2. Check MAP sensor
3. If your car is AT then it could be the Transmission range switches is on the way out.
Old Oct 26, 2016 | 09:28 PM
csmeance's Avatar
^Agree with the suggestions of the APP, MAF and Transmission range switch. I'd order all 3 and replace them.
Old Oct 27, 2016 | 01:04 PM
All trans switches are 8k miles old, replaced when I did the 2x3. Doesn't an APP sensor cause the car to run roughly? I haven't noticed any abnormal idling, but recently did get the Tighten Gas Cap error on the MID. I don't see how this could be EVAP related though.
Here's a video of the problem.
Old Oct 27, 2016 | 02:44 PM
truonghthe's Avatar
1. APP bad symptom include weird acceleration aka hesitation during WOT (pedal is push to the floor but throttle only register half the input) this is more noticeable during high temp. My TL does it when I move to Houston but after I replace the APP its does not occur again (NO CEL was given).
2. MAP sensor can goes bad and cause your computer not compute the amount of air being intake correctly therefore take a while for the computer to figure out what to do next. (I had similar experience in my Lexus and it turn out to be bad MAP sensor).
3. AT range switch is NOT 3rd &4th switches, this is the sensor tell the car computer what gear is the car currently in and is it safe to down shift/ up shift. Bad sensor can cause hesitation during WOT and irregular shift, You can check the sensor by slapping the gear into trip-tronic mode and do a WOT if the sensor is bad your gear indicator display will flash. (My TL did that and I had to replace the range switch) also if you using pedal or push the shifter into + the car sometime won't up shift and it will bounce off the rev limiter.
Old Oct 27, 2016 | 04:48 PM
OsK's Avatar
OsK
It seems as if your car is bucking in the video.....have you checked your engine mounts? Side and front engine mounts are most prone to failure. Your side engine mount is right by your windshield wiper fluid and drive belt. 90 degree triangle shape below metal bracket.
I'm not saying that's the issue....I don't think the engine banging against the firewall and flopping around under load would contribute to rev limit issue. At first I think it's your oil level but you said it's full. Are you sure?
VTEC Solenoid? lol.
Old Oct 5, 2017 | 09:21 AM
mayjarjar's Avatar
Acura Member
Hey guys! Sorry to bring up and old threat but I've been having no luck with the problem I'm having with my 08 TL Auto Base and I'm hoping I can get some suggestions on this threat. So my TL will not rev past 2000-2200 rpms when in 5th gear. It shifts perfectly fine through all the gears and it accelerates like new. The car runs perfectly fine except for this 5th gear problem. It's as if there's a review limiter that will not let it past 2200 rpms. I just tried replacing the APP Sensor last night and it didn't make the car a little more responsive (could be because I tightened the throttle cable a little) but it still has the same problem. I'm going to try and return the APP Sensor today. Any suggestions on what problem could be? A fuse maybe? Solenoid?
P.S. the CEL is not on and there are no codes being thrown
Old Oct 5, 2017 | 09:48 AM
How's your oil level and transmission fluid level?
WHy return the App sensor? I'd just keep it installed in there.
Old Oct 5, 2017 | 09:51 AM
it's odd that it's only a 5th gear problem. if it were the APP, then it would display problems in all gears
mayjarjar's Avatar
Acura Member
Oil and tranny fluid levels are good. I'm going to drain and refill both here in a week or so. And there's no reason to keep the app sensor in there considering the other one is perfectly fine. That's $170 I could spend on other parts to fix the problem I'm having
Old Oct 5, 2017 | 09:52 AM
it's almost like there's not enough fluid pressure in the transmission.. ya know
Old Oct 5, 2017 | 09:53 AM
mayjarjar's Avatar
Acura Member
Yeah, it's very strange. But replacing the app sensor was suggested to me by a few people so I went ahead and did that but no luck. I barely notice the problem with my 5th gear but now that I've noticed it I just want to fix it lol
Old Oct 5, 2017 | 09:55 AM
is there EVEN a problem?
doesnt even sound like a problem....
Old Oct 5, 2017 | 09:57 AM
What speed are you at when you're trying to pass 2k RPM in 5th?
Old Oct 5, 2017 | 09:58 AM
50mph
Old Oct 5, 2017 | 10:03 AM
mayjarjar's Avatar
Acura Member
I've gone up to 100 and shifted into 5 and it just stays at 2200ish rpms. When I have it in D the car will stay in 4th gear even when it's supposed to sgit to 5.. but since I don't typically drive super fast I don't really notice it too much. I'd still like to get this problem figured out
Old Oct 5, 2017 | 10:06 AM
yeah, there's nothing wrong with the car...
with my six speed, at the top of 3rd gear..i'm at like 100-110mph.
top of 4th gear is like 120mph
top of 5th gear is like 155...
and I have another gear!
My gut still says oil levels
Old Oct 5, 2017 | 10:07 AM
mayjarjar's Avatar
Acura Member
Definitely not a major problem I don't think so I'm not in a huge rush to fix it but I don't want to figure it out
Old Oct 5, 2017 | 10:08 AM
mayjarjar's Avatar
Acura Member
I'll look into it. I'm not too mechanically inclined though... How would I go about checking the oil pressure and Tranny fluid pressure?
cycdaniel
Dec 17, 2019 10:58 AM
IIDXholic
Oct 8, 2015 07:53 AM
Mike Bertram
Sep 10, 2015 09:27 AM
ninersfgiantsfan
Sep 9, 2015 01:14 PM
Phambam12
Sep 6, 2015 06:57 PM
