'07 TL Climate Control NOT WORKING
I have a 2007 TL and the other day the Climate Control stopped working.The Navigation controls under the screen work fine, But all of the other controls on both sides of the screen do not work. Meaning the mode button, a/c etc ..
I had a friend of mine do some work for my system and he was working with some wires under the steering wheel and near that fuse box and maybe he disconnected something or messed with the wrong wires? Is there a wire harness for those controls?
None of the fuses look to be blown under the hood or by the drivers side of the car under the dash.
ANY ADVICE would be helpful
Thank You
Thank You
He went through the install over the next day after I told him and we went through all of the fuses and none of them look blown. I havent even looked at the wires myself because i would have no clue. So there is a wiring harness or wires under the steering wheel?
Any update on this? I have a similar problem where I pulled my stock nav/radio be the sound was out (it was a loose power wire) and when I put the nav/radio back in the defroster was blasting and none of the climate control buttons worked. I replaced the transistor but same problem.
re-check all your wires, something is disconnected
VikDakid23
07-04-2012 09:56 AM
FrankWhizzite
07-22-2011 03:16 PM
