06 TL xenon light of Passenger side going on and off
Old Jul 16, 2010 | 06:59 PM
DeMAN's Avatar
My light on the passenger side seem to blinking on and off, for a time then coming back on. It may work find for a time (20-30 min.) and then start the process all over again. Is this a sign of it failing or maybe a loose wire, or ballast issue
Has anyone had any issue with there xenon headlight on the TL? Has anyone replaced the bulb it even a bulb issue?
Old Jul 16, 2010 | 09:34 PM
LoveMyTL-S's Avatar
Sounds like your headlight is going.
Old Jul 17, 2010 | 01:33 AM
2QAYL's Avatar
ahh that sucks.
Old Jul 17, 2010 | 04:20 AM
YeuEmMaiMai's Avatar
swap the bulbs around and see if the problem follows the bulb if it does it is a bad bulb if not you got larger problems
Old Jul 17, 2010 | 12:25 PM
01tl4tl's Avatar
thats the test! swap sides and see if the problem follows the bulb
If it doesnt its probable ballast issue
Any moisture inside the housing lens?
about 3000 hours use is the life of HID bulbs
If you use them to flash that shortens the life
Always replace bulbs in pairs to keep color and brightness matched
dealer cost is laughable 125 per bulb!!-ck kaixen or phillps brands as options for 100 pair or less
4300 stock color- 5000 a nice upgrade- any higher is hard to see the road with
Old Jul 17, 2010 | 06:04 PM
cjTL's Avatar
I'm Craig
Is the color of it changing in comparison to the other one? If so, then that's another sign that the bulb is about to go.
It might turn a yellow-pink color.
Old Jul 20, 2010 | 03:46 PM
big_mac65's Avatar
B-MAC
Ditto, I had this problem and that test confirmed it was the bulb. Which is the best considering the alternative options.
Old Jul 23, 2010 | 12:40 PM
DeMAN's Avatar
Whats involved in changing out these bulbs? Did anyone take there car to a shop to changeout the bulbs.
I also like buying bulbs in pairs. A newer bulb will always shine brighter.
Old Jul 25, 2010 | 08:46 PM
tn_viper's Avatar
6th Gear
I have this problem with an 04. I changed the bulb with a new one and it didn't help. Have also noticed a color difference between the sides. Mine wont just go off and no, it will go off and not come back on until the car is turned off and let sit for awhile. I am guessing it is a ballast issue.
Old Sep 6, 2010 | 12:46 PM
DeMAN's Avatar
Is the any instruction on installing both sides. (step by step instruction)
HairyMonkey019
Apr 22, 2016 10:50 PM
sockr1
Oct 1, 2015 01:31 AM
Ny1718
Sep 11, 2015 09:21 AM
JnC
Sep 11, 2015 06:06 AM
Steven Vitek
ILX
Sep 10, 2015 07:29 AM
