'05 TL transmission flush/drain/fill...
Old Jul 1, 2014 | 10:56 AM
blownby's Avatar
Some reading on here has lead me to the 3x3 method for draining and re adding. Is it simply drain 3 qts, fill 3 qts. Drive for a bit(how long)? repeat for total of 3 times....
Also have seen Redline ATF used as well as Honda DW-1 Atf...
Input please...
Car has 110k, new to me and just like to have all freshened up!
Supposedly all scheduled maintenance was done, so not sure when last tranny flush would have been?
Old Jul 1, 2014 | 10:58 AM
pohljm's Avatar
I would drive 1K miles between 1x3's so you dont shock it to bad at 110K.
Old Jul 1, 2014 | 11:53 AM
blownby's Avatar
Thanks,
Just a drain plug on these cars correct?
Suggest the Honda DW-1 fluid?
Old Jul 1, 2014 | 02:14 PM
Houston's Avatar
Here I come!
Yes on the drain plug. Is it auto or manual?
Old Jul 1, 2014 | 02:19 PM
blownby's Avatar
auto
Old Jul 1, 2014 | 02:31 PM
Houston's Avatar
Here I come!
In that case, you might also want to do the external ATF filter...
#7: http://www.oemacuraparts.com/auto-pa...peed-automatic
...and the 3rd & 4th pressure switches...
#12 & #13: http://www.oemacuraparts.com/auto-pa...peed-automatic
Old Jul 1, 2014 | 11:56 PM
michaelap95's Avatar
Thanks for this! In your opinion, is the DIY hard for either changes?
Old Jul 2, 2014 | 06:14 AM
Due_Diligence's Avatar
No they are pretty easy to tackle, just beware that if your tranny has never had the fluid changed you could risk a chance that redline will speed up the tranny failure process, "IF" it was on its way out.
Old Jul 2, 2014 | 12:05 PM
ggesq's Avatar
I'll shamelessly leave a link to this thread....
https://acurazine.com/forums/car-parts-sale-361/3gtl-tranny-filter-gasket-o-ring-new-913379/
Old Jul 2, 2014 | 02:10 PM
I changed the tranny fluid about a few months ago. I guess ill do another 3x3 then change the switches after this change.
Old Jul 2, 2014 | 05:50 PM
What's the mileage on your car?
Old Jul 3, 2014 | 12:27 AM
92k. Using all oem fluids in it since I purchased it at around 88k
knight rider
Mar 4, 2016 08:59 AM
joflewbyu2
Oct 8, 2015 11:16 AM
xsilverhawkx
Oct 5, 2015 11:00 AM
hashbrown
Sep 29, 2015 12:13 PM
ROSSARONIE
Sep 22, 2015 11:46 AM
